Question about Dell Computers & Internet
Emonster 550 wont load operating system wont read disk nothing can you help me please?
I have a used emachine monster 550 that was working offline great then it said 'PCI controller card not installed' I pwoered doen took cover off and carefully pressed on the boards one was loose and it clicked in . I pwoered it up and nothing no system loaed. I put the operatind disk in, nothing again, I put the dell monster 550 restore disk in nothing, Can you help me get the system up and running again? I have a bootalbe cd for the emonster550 I also have a windoes xp oeating system disk but I di not have a windows 98 operatiung systenm disk. What can I do? thank you Huricanelor
    President:
  • 948 Answers
Go into the BIOS (watch your POST screen as you turn the computer on for instructions if you don't know how to get in there, it will say something like "press F2 to enter setup") and set your computer to boot from your CD drive. Put your restore or XP disk in the CD drive and reboot.
Posted on May 17, 2009
Emachine t4010 wont read discs
Go to Device manager n see if any driver is missing or requires update.
Jul 06, 2012 | E-Machines eMachines Desktop PC
Emachine EL1852 keep on restarting
Does it load operating system fully before restarting?If it does,run a full scan of the drive with an updated anti-virus.
If not,do a reboot[enslave] of your hard disk from another computer.This is how to:-
Remove the hard disk from your machine.
Disconnect CD/DVD ROM from machine 2 and connect your hard drive.
Start the machine.'You're trying to run Unix' alert comes on, press f1[ save changes].
A disk check operation starts.This repairs the operating system on your hard disk.
After successful loading operating system of machine2,turn it off and remove your drive.
Fix it on your machine and start it.
Hope this helps.Thanks!
Sep 27, 2011 | E-Machines eMachines Desktop PC
How to change the boot priority on emachine?
eMachines - eMonster, eTower, eOne, S-Series, T-Series;
Press Tab or Del while the eMachine logo displays on screen.
Other eMachine computers may use F2 to enter BIOS.
HOPE THIS HELPS
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | E-Machines eMachines Desktop PC
Can I install Windows XP Professional on an Emonster 600 ?
Yes you can...
Installing Windows XP on a Emonster 600 is the same process as installing Windows XP on any Windows-compatible personal computer. The process is not difficult, and can be completed quickly.
#1 Insert the Windows disc and restart your computer. When prompted to press any key to boot from the CD, press a key. Windows will begin the set-up process.
#2 When a list of hard drive partitions appears, delete each of them by pressing "D" to delete and "L" to confirm deletion. When finished, you should only have one choice: "unpartitioned space."
#3 Press "Enter", then format using the NTFS file system. Do nothing while Windows begins to install.
#4 Wait for Windows to restart. When the process continues, enter the product key, the time and time zone, and your name when prompted to do so. Allow the installation to continue; it may take some time.
#5 when Windows restarts again, continue the process using the on-screen instructions. The process will vary depending on your hardware configuration.
#6 Connect to the Internet and activate Windows once you reach your desktop. If you can't, you can also activate Windows over the phone. Installation is complete.
Oct 03, 2010 | E-Machines eMonster 600 PC Desktop
Monitor screen while booting says out of range then turns blue.
while booting into the Operating system try pressing F8. It will take you to the os menu and select VGA loging in mode in that. Later after entering the operating system reduce your monitor resolution say 800 * 600 it should fix the problem.
Nov 27, 2009 | E-Machines eMonster 550 PC Desktop
Emachines t5212 system restore backup files, please help!!
If you only your files to be copied in the other or any storage disk then you can remove the hard disk of your machine and then attached it to the other functional machine. in there you can browse and copy all the important files. after copying all your files then you can take back the hard drive to your non functional machine and then install new operating system. documentation found here: http://support.microsoft.com/kb/316941
tell me if something wrong with your system when applying the solution.
melnavz
Feb 05, 2009 | E-Machines eMachines Desktop PC
EMachines eMonster 500A Restore Disk
I suggest finding the specific drivers that he deleted. Typically, when a computer begins to get slow, either 1 of 3 problems occur. 1. The drivers are insufficiently up to date. 2. There's too much clutter on the hard disk, RAM, and CPU. Lastly, driver files and start up files get deleted. The best way to fix that slow problem is downloading the driver files.
Feb 05, 2009 | E-Machines eMonster 500a PC Desktop
OS Wont load
You need to reinstall operative system, either using recovery disk, or using a generic windows setup disk.
If the computer does not read recovery disk, then it is probably scratched or faulty.
System reinstall is usually done at any computer repair shop for a not too expensive fee.
When hard disk is damaged you often also hear a typical clicking noise, and system stop shortly after post.
Aug 25, 2008 | Dell Inspiron™ E1505 PC Notebook
Computers & Internet Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
