Question about Radio Shack Archerotor Antenna Rotor - Rotator With 2 Rotors - Model 15-1225a
Archer 15-9986 I have one of the above rotators but have not been able to find the manual that came with it so that I can check the maintenance it requires
What year does Archer take place in?
The universe of Archer uses fashion and hairstyles from the early 1960s with a mix of 1980s architecture. Present-day technology such as smartphones and the internet as well as current social values such as the general acceptance of LGBT people and women in positions of power can also be seen in Archer. Countries that no longer exists today such as the Soviet Union still clearly exists in the Archer universe. "The Cold War never ended" is the most accepted theory put forward by the show's creator which mean's that Archer is set in the present day but in an alternate timeline from our own.
Sep 04, 2016 | Archer (2009)
What is an archer glove?
An archer glove us a glove made for professional archers which helps protecting both the drawing fingers and the bow hand.
Feb 06, 2013 | Clothing Accessories
What is a novice archer?
A novice archer is defined as an adult archer, who is pretty new to the sport of archery and in his first year of registering with GNAS, the governing body of archery in the UK.
Aug 26, 2012 | Betsey Johnson Archery
Why do archers shout Fast when they spot a danger?
Any archer who spots something dangerous can shout fast in order to warn other archers in his shooting session. Fast is short for hold fast which means to stop.
2005 cts @ 100,000 what service needs to be done?
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - EXHAUST SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - AIR CLEANER/ELEMENT - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL FILTER - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - SPARK PLUGS - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - TIRES - ROTATE - [Tires should be rotated every 5000 to 8000 miles, and/or at maintenance I or II service intervals.Check tire pressure, thread depth and wear.]
Feb 07, 2011 | 2005 Cadillac CTS
The system is not working at all and don't have any troubleshooting manuals or maintenance guides to solve the problem but i am sure from that I have a problem at the indoor thermostat but i had changed it...
Check indoor fan motor mechanism may be locked. Rotate manually. If rotates, replace fan capacitor. If hard to rotate, replace bearings or motor itself. Hope helpful.
Jan 10, 2011 | Heating & Cooling
Trying to find the owners manual for 2001 saturn sc2 as well as the maintenance schedule etc provided when the car was new
Scheduled Maintenance The service shown in this schedule up to 150,000 miles (250,000 km) should be performed after 150,000 miles (250,000 km) at the same intervals.
See Owner Inspections and Services for maintenance information.
Scheduled Maintenance Mileage
Maintenance Group No.
6,000 Miles (10 000 km)
18,000 Miles (30 000 km)
30,000 Miles (50 000 km)
36,000 Miles (60 000 km)
42,000 Miles (70 000 km)
50,000 Miles (83 000 km)
5
54,000 Miles (90 000 km)
60,000 Miles (100 000 km)
6
66,000 Miles (110 000 km)
72,000 Miles (120 000 km)
78,000 Miles (130 000 km)
90,000 Miles (150 000 km)
7
100,000 Miles (166 000 km)
8
102,000 Miles (170 000 km)
108,000 Miles (174 000 km)
114,000 Miles (190 000 km)
120,000 Miles (200 000 km)
6
126,000 Miles (210 000 km)
138,000 Miles (230 000 km)
150,000 Miles (250 000 km)
5
Maintenance Requirements - Group 1 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). Maintenance Requirements - Group 2 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Inspect the engine accessory drive belt and coolant hoses every 12 months or 18,000 miles (30,000 km), whichever occurs first. Maintenance Requirements - Group 3 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Replace the engine air cleaner filter every 36 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Inspect the vacuum lines/hoses every 24 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Replace spark plugs. An Emission Control Service.
Oct 05, 2010 | 2001 Saturn SC
2002 honda odyssey
Normal maintenance schedule at 75,000 miles:
Replace transmission fluid.
replace engine oil.
Rotate tires.
replace engine oil filter.
inspect brakes.
check parking brake adjustment.
inspect tie rod ends, steering gearbox and boots.
inspect suspension components.
inspect driveshaft boots.
inspect brake hoses and lines.
check all fluid levels.
inspect cooling system hoses.
inspect exhaust system.
inspect fuel lines and connections.
(At 90,000 do all of above plus:
replace air cleaner element.
inspect and adjust drive belts.
replace cabin air filter.)
Mar 22, 2009 | 2002 Honda Odyssey
Manual for archer a/v control center
I have the manual and will scan it for you. May take a few days. email me at kevin@onlink.net
Aug 23, 2008 | Electronics - Others
Radio Shack Archerotor Antenna Rotor - Rotator With 2 Rotors - Model 15-1225a Logo
44 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
