E3 code electric fireplace - Heating & Cooling
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Tip
Portable Heat Flame Electric Fireplace
Electric fireplaces are becoming more and more popular with today's homeowner's. The main advantage of the electric fireplace is generally portability, convenience, low initial cost is important. They also are a good choice when the looks are not as important as function.
Some electric fireplaces have simulated flames that give the look of traditional fireplaces. Another great option to include is a built-in fan to help distribute the heat more effectively. With some of these high end units it can be very hard to tell the difference between an electric fireplace and a wood burning stove. Along with this option may come a heatless setting the will give the look of flames but produce no heat. The remote control has also found its way to the fireplace market. There are many units that can be remotely controlled.
Electric fireplaces are generally cheaper than gas fireplaces. A good unit can be bought for about $500 (there are cheaper models available, but they tend to have fewer options and the flames are not as real looking). These fireplace units are fairly easy to install compared to a gas fireplaces or wood-burning stoves (both of which usually need flues to vent). If you can plug in an electric cord then this type of fireplace may be for you. The electric units are perfect for apartment buildings and condominiums. These places are not suitable for the traditional wood fireplace.
Just like other types of portable electric heaters, electric fireplaces will radiate heat very quickly extreme care must be taken to not have any combustibles too close to them.
You will see how an electric fireplace can transform any setting for you. The newest modern, advanced electric units have far more aesthetically appealing views. They might include fiber optic displays, or randomized lights designed to make the look of dancing flames.
Now whether you're living in a condo or apartment and can't have a real fireplace, the electric fireplace can be a great way to get some of the warmth and ambiance. Also remember that these units are very portable, so you can take them with you when it's time to move. Even though I have never been a big fan of electric fireplaces, because of the expense of their operation, I can see why they would be very popular with many apartment or condos owners.
http://www.fixya.com/support/r3707111-flame_electric_fireplace_electric
on Dec 25, 2009 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
How do change a bulb in a classicflame 23ef010gaa
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
Oct 29, 2015 | Cars & Trucks
When I turn my electric fireplace on, the fan blows for about 30 seconds and then quits blowing.
How to revive/lubricate your fireplace blower fan or any ...
? 26:34
www.youtube.com/watch?v=JbX_XtKS1p0
Jan 30, 2013 - Uploaded by varietytubechan My fireplace blower fan had stopped working. ... This is demonstrated on a FK4, GFK4, R7-RB74K (Electric Motor Warehouse), HB-RB74K ...
5 Electric Portable Fireplace Repair Tips ' DoItYourself.com
www.doityourself.com/stry/5-electric-portable-fireplace-repair-tips
Electric portable fireplaces are a convenient way to warm a room, barn, patio, ... If the light or coloring of the fireplace is not working, you may need to replace the ... is not working as well as it should, you may need to inspect and clean the fan.
Oct 26, 2015 | Dryers
Classic Flame 39EB500GRS Error Message E3?
I had same problem. Just stopped worked and blinked E3. I used the troubleshooting wizard on ClassicFlame's website. Shut power off (it's hardwired to 220v) for a couple minutes and it started back up. Never did find out what caused the error.
Dec 10, 2013 | Classic Flame 39EB500GRS 39 inch Builders...
Noisy fan on electric fireplace
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
Mar 17, 2013 | Leisure HOMEPRIDE Electric Fireplace...
How to replace my charmglow electric fireplace with a gas insert
Check your local building codes for restrictions. You MUST have the proper exhaust for a gas unit. There may also be flooring and wall requirements that need to be changed.
Jan 18, 2013 | Heating & Cooling
I have kitchenaid Kerc700 electric range that had the code F2:E3 show up on the display. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.Kitchenaid F2-E3 means a button was held down too long if you push cancel and it comes back you would have to replace the glass console. Thats assuming its F2-E3 and not E3-F2
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid KERC700 Electric Kitchen Range
Heating & Cooling Logo
775 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
