Question about Kodak Office Equipment & Supplies
Kodak Ektagraphic AF-1 will not advance or reverse
My Kodak Ektagraphic AF-1 will not advance or reverse using either remote or buttons. When the buttons are pressed the courtesy light dims ever so slightly. I am using a stack loader with it. It was working great all night, until I reversed a frame or two. The select button works fine.
  • Jerry Mann
    Jerry Mann Dec 26, 2013
    I am willing to work on this myself... fairly handy guy.
    President:
  • Kodak Master
  • 412 Answers
If the select button functions correctly, Chances are the direction lever in the mechanism is bound up or the Direction Lever Spring is broken. If the Spring is broken or the Direction Lever is bound up, the Index Lever will go out straight when the Advance / Reverse buttons are pushed - instead of moving out straight , then moving forward or reverse at a 45 degree angle.
The Slide Change mechanism needs to be re-built. The bad news is this projector was manufactured from 1976 to 1984. Kodak scrapped the repair parts in the early 1990's. Your best bet is to find a repair shop that has a projector that they can salvage parts for your projector from.... Good Luck !!
Posted on Jan 14, 2014
3 Suggested Answers
  • 412 Answers
SOURCE: kodak ektagraphic AF 1 reverse does not work -
If there are no broken components of the slide change mechanism and it is only an adjustment problem, do the following:
1. Remove the bottom cover
2. At the front of the projector (near the elevation wheel) you will find (2) 1/4" head screws going through black rubber grommets. Loosen the screw slightly.
3. Next to the screws you will see a cutout in 2 pieces of metal that when looked at together, resemble a diamond shape.
4. With the projector on in FAN mode only (NO LAMP!), simultaneously press the reverse button on the side of the projector and with a flat-blade screwdriver inserted into the diamond-shaped slot, twist gently to move the plate the 2 screws go through up or down until you get cycling in reverse. If you go too far you will get buzzing, which will indicate that the solenoid plunger is bottomed out in the solenoid coil. Once you get acceptable reverse cycle, tighten the 2 screws gently and turn the projector right-side up. Verify the correct action in both forward & reverse cycle. Adjust further if necessary. If OK, tighten the 2 screws and re-install the bottom cover. You're done!
Posted on Nov 22, 2010
  • 412 Answers
SOURCE: Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
Posted on Dec 26, 2011
Carousel won't advance, fwd, back and remote doesn't work, just makes a faint buzzing sound, as does the timer. Select button sounds right but doesn't catch the slide.
open and clean everything. use brushes, a vacuum cleaner....
You still hear a buzz? good! the motor is still alive. Now it's time to liberate the movement. What is blocking?
When some (old) plastic won't slide smoothly any more, adding oil makes the problem worse! Don't do that. On such plastic I found that rubbing some candle wax makes a good lubricant. Good luck!
Sep 21, 2014 | Kodak Ektagraphic Slide Projector Af-2...
Fix focusing on ektagraphic remote control
Ektagraphic III A did not have remote focus. Someone has probably substituted a remote from a higher functioning model on this projector. The forward / reverse functions on the supplied remote will continue to function correctly, but the focus buttons will not.
Good Luck !! Jim
May 20, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Slides continue to advance,wont stop
The continuous cycle is caused by the slide change clutch contact. This contact is either burned off from excessive use or has somehow moved out of correct adjustment. I have attached an image that might help you identify correct alignment. For parts, contact: www.micro-tools.com
Jan 29, 2013 | Kodak Ektagraphic III ATS Slide Projector
I'm trying to find a manual for a Kodak ektagraphic AF-3
You should still be able to get an AF-3 manual (e-copy) from the Kodak website, or contact the George Eastman House Museum. Good Luck!
Jim
Mar 19, 2012 | Kodak Office Equipment & Supplies
Good Luck !! Jim
Dec 15, 2011 | Kodak Office Equipment & Supplies
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
My Kodak Ektagrafic AF-1 Projector just stopped advancing and reversing while I was reviewing slides. I had been using both forward and reverse buttons. There is nothing stuck in it. It will not advance...
The KODAK Ektagraphic AF-1 was manufactured from approximately 1971 to 1981.
The problem you are describing is most likely a broken cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is made of plastic, which gets hard, brittle & could break over time.
Parts are still available, but the repair process is a intricate one. My best advice is to seek out an Authorized Repair Dealer.
Aug 11, 2010 | Office Equipment & Supplies
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
Kodak ektagraphic AF 1 reverse does not work - anything I can do?
Apr 24, 2010 | Kodak Office Equipment & Supplies
AF-3 carousel, lamp on but light guard prevents picture
Based on your description, I suspect the coil spring that tensions the "dark shutter" has either broken or has popped off it's mount. To be absolutely sure, take your projector to a factory-trained repair dealer.
Feb 13, 2010 | Kodak Ektagraphic III E Plus Slide...
268 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
