Question about Honda 2001 Odyssey EX
I am having trouble to remove the interior panel of tailgate. I was able to remove the two screws underneath the handle from the panel but unable to remove the two screws beside the latch locker at th
I looked online diagram and some diagram labels these two plastic screw as "clip". both plastic screws appear to be surrounded with plastic shells. both plastic screws located at bottom of tailgate and hold interior panel in place. the latch locker locates between these two plasic screws. I used cross type screwdriver to loose both screws but completely damaged the screws cap. both screws can be turned by screwdriver both directions freely but never came out. I don't know what else I can do about it.
    Problem Solver:
  • 14 Answers
These retainers are like a rivet or dry wall plug take a small flat blade screw driver and a Philips (or star) lightly pry up on the shoulder of the middle pice while turning counter clockwise the centre should back out remove it then with the flat blad gently pry outer pice from hole good luck hope this helped you
Posted on Dec 26, 2013
How to open the tailgate if handle or cable is broken on 2003 sequoia
I had the same problem with my 02 Sequoia. To get the tailgate open and replace the broken handle you will have to remove the tailgate's panel cover.
The panel is affixed to the tailgate with about six to eight plastic stays on the back side of the panel.
You will need a "L"-shaped tool (The tool looks like a screw driver with its tip bent one-to-two inches.) that can be inserted under the panel's edge. Start @ the right, or left bottom corner.
After you pull the panel's second plastic stay away from the tailgate you will be able to use your hand to pull the rest of the stays away from the tailgate then push up on the panel to remove it.
After the panel is removed you will be able to see where the cable feeds into the broken handle. Use a pair of needle-nose pliers to pull the cable and open the tailgate. Toyota charges $100.00 for a new handle.
Hope this helps and is not to confusing.
Oct 09, 2011 | 2002 Toyota Sequoia
Rear hatch on my 2001 explorer will not open, rear window will but tailgate hatch will not. how do i open it with out the unlock button, no manual release that i can see...
I had a clip break when I tried to open my tailgate. I had to remove my inside hatch panel and find my way to the handle assembly. A little plastic clip (shaped like a T) had finally worn out, which wouldn't hold the locking arms, and I had to go to a Ford dealership for a $3 part; tailgate has worked fine since then!
Sep 01, 2011 | 2001 Ford Explorer Sport
The rear tailgate windshield washer tubing is loose in the tailgate so when the sprayer button is pressed fluid is squarted inside the tailgate. How do you repair this? I think the interior panel on the...
if you don't find any screws then it is held in place by push pins. Make sure you check for cover caps near any interior release handles. These push pins are plastic and typically are spaced 8 to 10 inches apart all the way around the outer edge. You have to pry these up carefully and make sure they come our of the metal and not out of the panel itself. They are replaceable and available at Auto Zone and Advance Auto in the generic section.
Apr 30, 2011 | 2007 Chevrolet TrailBlazer SS
Tailgate won't open, broken latch. how to fix? 2000 Ford Explorer sport.
If you can find a used one it is much cheaper (obviously).You need to pull off the tailgate interior panel covering.Also you may not.There may be access to it from underneath.I have pulled apart windows,doors but have never had a truck or SUV.There may be some screws holding down the interior cover in a few spots.If you have to pull apart the interior panel,look for screws that may be capped with those little plastic covers,they like to hide the screws for appearance.Then you will have to gently pry at the seams between the cover and the tailgate.There are usually little pop in pins holding it on.Please do it carefully because they can break.Once you get past the interior cover,there should be access to the latch.It's usually only held on by a couple of medium size bolts,maybe 10mm-12mm.(Everything seems metric these days anyhow).Good luck and let me know if you need further help or have any questions.
Jul 30, 2010 | 2001 Ford Explorer Sport
Tailgate will not open; handle will not move
Either ,something is binding inside the tailgate, or broken.
You can get to the mechanism from the inside panel of the tailgate-- by
removing the screws that down the inside panel.
Once you remove the panel you should be able to open the tailgate by
pulling on the thin cable to unlatch the latches from both ends of the tailgate and a good look at the handle mechanism will tell you what wrong.
Good Luck.
Mar 20, 2010 | 1991 Nissan Pickup
89'S10 Blazer tailgate won't open. How to release/open? Glass will release and open but tailgate will not drop. Knob will only turn as far as when the glass is down. A schematic with parts showing how the...
Thats what you will need to do is to remove the interior gate panel so you can release the latch. It will come off although a bit difficult with the gate closed, with a little care you can do it without breaking anything. It sounds like possibly a linkage retainer clip broke.
Try pushing in on the gate while turning the release handle in case the latch is in a bind if that dont work remove the panel
Nov 17, 2009 | 1989 Chevrolet S-10 Blazer
Tailgate on 96runner won't 0pen. Window works, fuses ok, latch won't engage to open tailgate
You are gonna have to remove the interior panel, and with pliers, open the hatch...either the clip is broken on the handle or the handle itself is broken.
Oct 25, 2009 | 1996 Toyota 4Runner
2002 Ford Ranger Exterior Tailgate Handle Broken
There should be an access panel on the bed side of the tail gate. If you have a liner installed on the tail gate you will need to remove it to gain access to the panel. Panel is probably held on with torx screws but you may get lucky and have regular bolts. just remove panel and the lock rods are held to the handle with little clips, just pop them off and remove the nuts that hold the handle assembly onto the tailgate, install is just the revers order.
Jun 21, 2009 | 2002 Ford Ranger Regular Cab
Tailgate won't open
jg-demedina- 2 solutions 1. remove all screws including 2 screws mounting interior pull handle, then remove the interior panel by steadily pulling away the panel. You will hear the panel clips popping as you pull away the panel. Some of the clips will break...but not to worry...50 cents a clip at the Chrysler dealer. This panel comes away from the interior of the door just like every other panel does on every other car! 2. Do not take the advice of this person you are calling a mechanic.
May 09, 2009 | 1999 Jeep Cherokee
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Honda 2001 Odyssey EX Logo
57 people viewed this question
Top Honda Heating & Cooling Experts
bigdawg7299
Thomas Perkins
Thomas Perkins
ray gallant
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
