Belkin Wireless Router
Problems with wireless connections/router (Belkin)
posted by patty_gooch on Oct 17, 2007
Hi, can anyone help?
                              After attempting to setup a wirless network i am experiencing problems when trying to maintain a connection. Often the network will not appear on the "view wireless network" list and when it does it very often will not connect. On the rare occasion when i am able to connect, the Speed/Mbps seems unreasonably low and it is never very long before the connection is lost. I am using cable modem. I've tried restarting the router and modem (turning off and waiting 5mins), ocassionally clicking on repair causes the connection to appear. I've got a feeling my next-door-neighbour has the same router (unsecured), are we both using the same channel? Any advice at all would be helpful as it's driving us all up the wall!!! Thanks Patty
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 17, 2007
Helpful (85)
wms702
Rank:Apprentice Apprentice
Rating: 90%, 2 votes
There may be a conflict.  Have you configured your router?? Make it a Shared , Secured, WEP connection. Configure your router by going to:
http//:192.168.0.1
Comment posted on Oct 17, 2007
Depending on your computer and router, you may automatically be able to connect wirelessly to yuor new router to begin configuration. However, it may be necessary to patch into the router with a nearby computer via an Ethernet cable. Whichever method you use, you'll need to reboot the computer.
To configure the D-Link router, you will next need to open a web browser and type http://www.192.168.0.1
You should see the administration screen of the D-link router. type in admin and leave the password filed blank.
A setup wizard should appear, prompting you to first change the router's password. Pick something you can remember.
You will next have to setup a time zone, you will then be given option as to how the router will handle IP address on the network. Most users will opt for the Dynamic option, which means the router will act as a DHCP server and supply all computers on the network with an IP address. If you select DHCP, you will need to Clone the IP address of the machine your ISP has already had contact with. For instance, if your ISP has been giving IP address to a certain computer before you put the router between them, you will need to clone the MAC address of that machine.
If you opted for Static IP Addresses, you will be brought to a screen that you will need to contact the ISP to get IP numbers from.
You will next need to setup the wireless connection. You will change the default SSID to match the workgroup ID of your LAN computers. The SSID and the Workgroup IDs must match. You will also be able to configure encryption at this point. If you have the ability to use the newer WPA encryption, you will want to use this. But we don't recommend setting up encryption untill you confirm that all PCs are able to connect properly.
Lastly, you will be asked to reboot the router.
Rating Locked! (?) patty_gooch has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problems with wireless connections/router (Belkin):
I don't want to Accept this solution
Can you Help with these Routers problems?
Routers
I have the Belkin n wireless router i do not know the...
Routers
what is the role of router in wan technology?
Belkin (F5D7231-4) Wireless Router
I cannot connect to my Belkin router with two laptops that...
I bought a wireless router and hooked it up as the manual...
Hi, I'd like to use this router to bridge a broadband...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
