Question about Juicers
Cuisinart handle well not realise - Juicers
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Need place in 60439 zipcode to get omega juicer repaired
What's wrong, you might be able to handle it yourself.
You can also call Omega for help. 1 800 633 3461.
Sep 30, 2010 | Omega 1000 Juice Extractor
Amazing juicer cant take apart to clean i have no instructions
You should have a little handle lock with it, that you attach to the holes on the mesh sieve, that lifts it out, then the rest can be dismantled.
Sep 03, 2009 | Juicers
Santos 28 wont switch on
Problem with internal micro switch,no power suply or locking handle not activating safety switch
Jul 08, 2009 | Matfer SANTOS Juicer
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Smitty
Jun 06, 2008 | Jack Lalanne Power Juicer (Stainless...
Clean the pulp
yes you take it off with the orange handle (separate part)- it fits in two holes and you tighten or loosen it.
Nov 28, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
22 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
