How do i connect my vibe sound bluetooth speaker pod
My bose bluetooth mobile won't link to my apple I pad,when I try to link them ,my I pad tell me that the sound system is not on
Switch your Bose Speaker off.
Open iPad - Settings - Bluetooth - Switch Bluetooth Off
Switch iPad Bluetooth On and quickly switch Bose Speaker On.
They should talk to each other as they find each other and fall in love :>)
Bose Bluetooth speakers from I-pod are listed in the link below with manuals.
On my Bowers and Wilkins T7 Bluetooth speaker you have to press the Bluetooth button on the SPEAKER the first time you connect it. After it is paired, it finds itself as soon as the speaker is turned on. I can highly recommend the B&W T7.
BLUETOOTH Speakers Bose
Jan 02, 2016 | Apple Bose SoundDock Series II Digital...
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
Speaker wont connect to bluetooth
Go to your Bluetooth settings and forget the device. Then re-pair it for a fresh connection. This worked for me
Apr 12, 2014 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
Iwave pod bluetooth speaker
Unless your PC is Bluetooth capable, you'll need to get a Bluetooth device to make it so. This is just one of many such devices to select from. Amazon com Roker Ultra Mini CSR Bluetooth 4 0 Usb Adator for PC and... They vary in size and price. Shop around to find one that best suits your budget. But you want an adaptor/receiver specifically for Bluetooth. (you will need an empty USB port for the adaptor)
Hope this information helps, best of luck!
Feb 06, 2014 | Audio Players & Recorders
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
Loss of sound to pc speakers after installing Bluetooth speakers
Computer is sending signal to bluetooth only. Check in your sound settings to see if computer will allow enabling of both. Hope this helps.
Dec 22, 2008 | Logitech Z-560 Computer Speakers
64 people viewed this question
 Grubhead
Grubhead
