Question about Zyliss Easy Spin Large Salad Spinner
My Zylis lettuce spinner won't spin - Zyliss Easy Spin Large Salad Spinner
What is fidget spinner made up of?
Fidget spinners are the type of fidget toys which are made up of various different types of materials.
Basically, they are made up of metals like made of steel, copper, plastic, brass or titanium. Some spinners are also available in 3D printed designs.
These Fidget Spinners toys have become very trendy today due to its various health benefits.
Jun 02, 2017 | MADE Computers & Internet
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
How do you make salad?
http://en.wikipedia.org/wiki/Salad_spinner
the spinner removes water from lettuce leaves to allow oil (salad dressings) to stick to the leaves. Spin salad then put in a bowl and mix with a salad dressing .
Nov 02, 2014 | Home
How should I dry lettuce if I don't have a salad spinner?
I don't have a salad spinner at home. All I do it rinse the lettuce, leave it basically "standing up" inside of a collander and let the water drip off. If I don't have enough time to leave it til it drys on its own, I sometimes shake it out and then wrap in it paper towel for a few minutes.
Jul 11, 2013 | Home
Where can I buy a salad spinner? It'd be a bonus if it had a brake in it to stop the spinning.
With a brake!! enjoy :)
http://www.target.com/p/oxo-salad-spinner/-/A-628331
Jan 14, 2013 | Home
What does a salad spinner do?
A salad spinner washes and takes away extra water from the lettuce/spinach/etc. The lettuce spins around which creates a centrifugal force. This force gets rid of the water.
Jan 14, 2013 | Home
Spinner will not spin
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
Dec 17, 2009 | Kenmore 22422 Top Load Washer
I put the game in but the disk does not spin
try cleaning the spinner and laser and make sure the spinner and game make contact to where they spin. it might be that your tray is kind of crooked and it misses the spinner to where the game wont spin.
Dec 08, 2009 | Sony PlayStation 2 Slimline Console
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Game spinner
It could be from a lot of different reasons. I would suggest finding a local repair shop or just buying a new one. There's not easy solution unfortunately.
Feb 19, 2009 | Sony PlayStation 2 Slimline Console
Zyliss Easy Spin Large Salad Spinner Logo
66 people viewed this question
Top Zyliss Dishwashers Experts
Are you a Zyliss Dishwasher Expert? Answer questions, earn points and help others
