Question about Frigidaire FPCO06D7MS Professional 6-Slice Convection Toaster Oven
Frigidaire FPCO06D7MS mode dial not working - Frigidaire FPCO06D7MS Professional 6-Slice Convection Toaster Oven
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Frigidaire Professional toaster oven is displaying E02 error what do I do ?
Oven temperature too hot. Check and replace oven temperature sensor (RTD)
Sep 27, 2014 | Frigidaire Professional Convection Toaster...
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
What does error code e02 indicate?
I had one with the same problem. I found out that this was due to a defective temperature sensor (in my case anyway). The technical name for this part is NTC glass encapsulated thermistor 86k ohm. It is placed against the outer right wall of the toaster oven. if you look into the oven,there are 2 screws holding it( this device is on the other side of the wall and is connected to the controller via a 2-pin white connector. I replaced it and my toaster oven works fine after. This part costs about 1-2 dollars to replace. You have to remove the top cover of the toaster oven to have access to it.
Feb 13, 2014 | Frigidaire FPCO06D7MS Professional 6-Slice...
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Farberware Turbo Oven T4850- can't understand temp dial
Use an oven thermometer to test it the temperature at the various dial settings to see which is which.... Good luck!
Dec 08, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Cuisinart Model TOB30BC Control Function
I have the same Cuisinart toaster with a different problem. In taking it apart to try and fix it, I may have gained insight in to fixing your problem. If your are willing to get under the hood of your toaster, you might try working with the electronic contacts that the function dial controls (it might void a warranty, but since you are out of warranty period no problem):
1. Unplug it from the wall
2. Remove the stainless steel case from around the toaster via the small screws around the toaster's bottom, sides, back and the black screws at the top just inside the door. This should allow you to see the electronics behind the dials.
3. Look at the function dial. by turning it you are turning a white plastic cam which presses down different combinations of metal electrical contacts to make the functions work. I suspect there is something wrong with the contacts that are pressed down to control the "BAKE" function. Turn the function dial to "BAKE". and Check the contacts that are pressed down by the cam.
4. Are the contacts free of crud or corrosion? If not, try cleaning them with a small brush or q-tip with CLR or some other rust remover or degreaser. After cleaning let them dry and plug in the toaster (once plugged in do not touch the electronics!) and try "BAKE" for a second. Turn it off and unplug it. If it works, reassemble. Otherwise try step 5.
5. Are all of the contacts pressed down by the cams completely in touching the metal on the plate like they are supposed to? If not, try bending them so they will touch when closed by the cam (but remain open when the cam is not pushing them). Are the contacts free of crud or corrosion? If not, try cleaning them with a small brush or q-tip with CLR or some other rust remover or degreaser. After cleaning let them dry and plug in the toaster (once plugged in do not touch the electronics!) and try "BAKE". If it works, unplug it and re-assemble.
6. If its still not working, email me (caseytronic@go.com). Maybe I can help. I am also willing to buy your toaster so I can fix mine.
Jan 09, 2008 | Cuisinart TOB-30 Toaster Oven with...
Frigidaire FPCO06D7MS Professional 6-Slice Convection Toaster Oven Logo
47 people viewed this question
Top Frigidaire Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Frigidaire Toaster Oven Expert? Answer questions, earn points and help others
