Question about Microsoft Xbox 360 Console
All the games I play come up on the TV really blurry
What would cause my xbox 360 to lose clarity? All the games I play come across my TV very unclear. I have 2 xbox's so I was able to test and make sure there is nothing wrong with my TV jacks or my cables, what inside the xbox can go bad to cause this?
    Problem Solver:
  • 19 Answers
It could be the connectors on the back of the system or the actual video card. i would double check the settings on the 360 if you can see them. If not call 800-4-myxbox and talk to the technical support personnel they are very good to work with.
Posted on May 18, 2009
While playing a game i switched the hd cord from hdtv to tv and it shut down. Now when i play games there are black or white pixel all over the screen.
always turn off the console first before switching from HDTV to TV the frequencies are really different it may cause further damage on the TV
Feb 08, 2011 | Microsoft Xbox 360 Console
I Am having blury games on my Xbox 360
There are many reasons for blurry screen on Xbox 360. If the problem is a particular game than, just try playing some another game. And if the problem is with all than the issue is most likely related to a setting on your television or to the connection between your Xbox 360 console and your television. You will want to make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. Make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV. Also, make sure that you have the correct AV cable for your TV.
Jan 29, 2011 | Microsoft Xbox 360 Hard Drive (20GB)
Black pattern efferct when I play any game on my Xbox 360
Make sure your cables are connected properly, It would also be helpful if you can try on another tv.
If the problem is solved, your TV is not supporting 60hz video or is dying.
Hope it helps
Jun 20, 2009 | Microsoft Xbox 360 Console
When I play Halo 3 it turns green. and other games get blurry in background, I just bought Fable 2 and I cant play that because it is too blurry, its not a scratched disc, and I rmoved dust in my 360
you may have a faulty AV lead, from xbox to TV.
or the graphics chip is failing, if you have a composite lead ( red-white-yellow-green-blue ) check that the switch is set to hdmi correctly. this is on the side of the oval connector from xbox outlet to tv lead.
try tuning into a different tv channel, check that the lead isn,t broken internally.
If this does not work, assume that the GPU Or graphics chip has come loose, and obtain A RROD repair kit.
Mike @ Compurepair.
Jun 12, 2009 | Microsoft Xbox 360 Console
In-game graphic breakdown
Sounds like an issue with the graphics card in the system. Call up Xbox 360 Support, or return it for a new one.
Apr 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Two XBOX 360 Games won't play on original XBOX Console?
Erm, the clue is in the name guys. ORIGINAL XBOX plays ORIGINAL XBOX games. The XBOX 360 plays games designed for the XBOX 360 plus an array of ORIGINAL games. The original console will NOT play 360 games.
Nov 29, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
66 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
