Question about HP Pavilion a6228x PC Desktop
I am looking to get a new hard drive for my pc.
I am looking for something that is compatible with this computer and if there is anything else that will help it out. It has an upgraded graphics card (ati radeon 2600pro) and I would like to use it for gaming more.
  • HP Master
  • 27,725 Answers
Add more ram is it uses a lot of graphics it might be slow adding more Computer ram will make it faster.
HP Pavilion a6228x Computer Memory.
The HP Pavilion a6228x Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2 Memory Type, and comes installed with 2.0 GB (removable) of Memory.
You can upgrade your HP Pavilion a6228x Computer to up to a maximum memory capacity of 8.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB (removable) standard memory installed.
For best Pavilion a6228x Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use theCrucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible
Posted on Dec 26, 2013
Testimonial: "That's great about the ram but it didnt really answer my question about a hard drive."
SOURCE: pc gaming issue
how do i fix my prism3d engine on my pc
Posted on Oct 12, 2008
  • 40 Answers
SOURCE: pc beeps five times when swtched on
PC beeps are usually memory-related problems. make sure you are using the right memory for your computer. the specs should be a DDR2 DIMM 240 pin PC2-3200. what specs do you have?
also do you have two 1G memory sticks or just one 2G memory stick? it may be that your computer doesn't accept a 2G memory stick but rather 1G memory sticks. good luck.
Posted on Dec 26, 2008
Zulfir
  • 73 Answers
SOURCE: "Call of Duty" runs in slow motion on my PC.
Yes Thomas, You can install a video card such as nvidia 9000 series.... That will definiely increase the performance of the computer.
Posted on Mar 20, 2009
  • 357 Answers
SOURCE: HP D530 Video card upgrade
If the HP D530 has an AGP slot, which I think it does, then yes you can install the Radeon HD 4350 card.
Make sure you have the correct driver for the video card.
Go to this site for more info:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00059123/c00059123.pdf
Hope this helps.
Good Luck.
  • 34 Answers
SOURCE: ATI Radeon 9250 PCI card not recognised.
Make sure the slot isn't disabled either by jumper settings or in the bios, and the card is securely inserted in the slot. If these aren't the case, you have yourself a bad card, or a bad slot.
Posted on Apr 30, 2009
The boot process stops at intel logo
When after inserting a new thing in a device, it stops, you have to assume the new thing is defect, or at least not setup to work in that device. Before you change a hardest, you must be sure it is 100% compatible. Not because the cable looks the same, makes it compatible. There are differences like speed and for the same interface. Sometimes one of the devices is downward compatible, but to always.
Feb 21, 2015 | Computers & Internet
Where can I buy a new hard drive for a Sony Vaio VPCSC?
Amazon and eBay are usually good sources for computer parts. Once you know whether it's an IDE or SATA drive you should be able to find something compatible.
Dec 30, 2012 | Computers & Internet
I want to install a new motherboard what should i buy
Your motherboard is the main component to your computer, so if you're thinking of re-using your RAM and CPU, you'll have to make sure you get a motherboard with the same RAM type (ex. if you have DDR2 RAM, you'll have to get a DDR2 motherboard) and the same CPU socket. My recommendation is that you find a motherboard that fits inside your tower, and buy a processor and RAM that is compatible with your new motherboard. If your hard drives are SATA connections, you should be able to reuse those on a new motherboard, but if they are IDE (big, flat wire) then you'll need to made sure the new board can accommodate your IDE hard drives. CD ROMs are also mainly SATA now, so if you have an IDE CD rom drive and IDE hard drives, it will be difficult to find a NEW motherboard with more than one IDE connection, meaning you'll have to change jumper settings, or simply buy a SATA CD-rom drive.
As far as software goes, you'll most likely have to reinstall your operating system if the upgrade is a substantial one. Video card is another thing to consider. Your motherboard might be using the older AGP technology, whereas new motherboards are useing PCIe connections. So to sum it up, when you upgrade your motherboard, it affects a lot of other hardware, but if you simply swap your motherboard with something compatible with the rest of your hardware, it isn't really an upgrade.
Jul 11, 2012 | HP PAVILION M8200N PC Desktop
Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
May 23, 2012 | HP Omni Computers & Internet
Needa external harddrive for the acer aspire one series mini labtop
If your computer has an external USB port, then any external storage device (memory-stick or external disk-drive) will be compatible.
Mar 28, 2011 | Computers & Internet
I replaced my HD on Dell inspiron 9300 and it won't recognize the new drive. The new drive was also purchased from Dell and was one that was compatible with the computer. It's saying there's no bootable HD...
It probably has found your new HD, you need watch the screen as you attempt to boot. Failing that enter the bios (usually " hit DEL to enter setup" appears on the screen. Don't change anything but just check to see if the bios has detected a hard drive.
Now .......... the reason why it won't boot is because you have to re-install windows onto the hard drive.
May 04, 2010 | Dell Inspiron 9300 PC Notebook
Specs for a Hard Drive
Anything you have should fit in there, you will have to upgrade the operating system, but the hard drive shouldn't be a problem so long as the computer is new enough to auto configure the hard drive.
Apr 25, 2010 | Gateway Essential 400 PC Desktop
I have an acer aspire 4721z laptop. the hard drive went bad, how can i replace it. Do i just buy a new one and install it. and if i do i dont have to do anything else. please help!!!!!
AS long as you buy a hard drive that is compatible all you need to do is look for te disc icon on the bottomof te machine remove the screws and pop it in ther eit is as simple as that
Apr 05, 2010 | Acer Aspire4720 14.1-inch Notebook PC PC...
How do you transfer hard drive from old comp. to new?
For just the data, get an ide to usb converter and connect it to the new computer, and just drag and drop.
You cant move an entire hard drive to a new computer because of driver issues, but you can use windows built in files and settings transfer utility.
IDE to USB: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
Dec 30, 2009 | Gateway 700 XL PC Desktop
I would like to change my hard drive
If you are looking to save just a "small" bit of $ .. 2 - 1GB sticks should be cheaper .. but what is the current configuration . is it 1 - 1GB or 2 - 512MB or 4 - 256MB?
You have the option of IDE or SATA drive so either is an option .. You may want to get a drive copy utility and just "clone/ghost" your current to the new drive and then swap it to master and GO
Dec 26, 2008 | Dell Dimension 4600 PC Desktop
HP Pavilion a6228x PC Desktop Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
