Question about Apple iPod touch
Disabled itouch my ipod is disabled I want to no how get back n my ipod
Try restoring the iOS device if backing up and erasing all content and settings doesn't resolve the issue. Using iTunes to restore iOS devices is part of standard isolation troubleshooting. Restoring your device will delete all data and content, including songs, videos, contacts, photos, and calendar information, and will restore all settings to their factory condition.
Before restoring your iOS device, Apple recommends that you either sync with iTunes to transfer any purchases you have made, or back up new data (data acquired after your last sync). If you have movie rentals on the device, seeiTunes Store movie rental usage rights in the United States before restoring.
Follow these steps to restore your device:
1. Verify that you are using the latest version of iTunes before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the Back Up
option (see in the image below). If you have just backed up the device, it is not
necessary to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up,
you should not have to worry about restoring your iOS device).
8. When the restore process has completed, the device restarts and displays the Apple
logo while starting up:
After a restore, the iOS device displays the "Connect to iTunes" screen. For updating
to iOS 5 or later, follow the steps in the iOS Setup Assistant. For earlier versions of
iOS, keep your device connected until the "Connect to iTunes" screen goes away or
you see "iPhone is activated."
9. The final step is to restore your device from a previous backup.
If you can not restore your device then you will need to go to recovery mode.
Placing your device into recovery mode:
Follow these steps to place your iOS device into recovery mode. If your iOS device is already in recovery mode, you can proceed immediately to step 6.
1. Disconnect the USB cable from the iPhone, iPad, or iPod touch, but leave the other end
of the cable connected to your computer's USB port.
2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the
red slider appears, then slide the slider. Wait for the device to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake
and Home buttons at the same time. When the device turns off, release the Sleep/Wake
and Home buttons.
3. While pressing and holding the Home button, reconnect the USB cable to the device.
The device should turn on. Note: If you see the screen pictured below, let the device
charge for at least ten minutes to ensure that the battery has some charge, and then
start with step 2 again.
4. Continue holding the Home button until you see the "Connect to iTunes" screen.
When this screen appears you can release the Home button.
5. If necessary, open iTunes. You should see the following "recovery mode" alert:
6. Use iTunes to restore the device.
Posted on Jan 01, 2014
4 Suggested Answers
SOURCE: i bought an itouch 2nd hand and its disabled
all you do is buy a new one duhhhh
Posted on Jun 09, 2009
  • 4 Answers
SOURCE: ipod is disabled
Hold down the menu and top button to reset.
Posted on Aug 11, 2009
SOURCE: if just says ipod is disabled try again in 4984418
i have an itouch... when i turn it on it just say ipod disabled try again in 20967586 what do i do?
Posted on Feb 19, 2010
Unlock my disabled itouch
just restore you iPod using iTunes
Oct 27, 2011 | Apple iPod touch
Tip
Fix Disabled ITouch that ITunes will not recognize
If your itouch reads "disabled connect to itunes" and shows the "locked" icon and your itunes will not even recognize the device and itunes says your itouch is locked and enter password, Here is what you do to restore your itouch: (you will lose all itouch contents but it is worth it as almost all say it is broken and worthless)
1. Turn off your itouch or ipod. Do not have charger / usb connected to ipod or itouch.
2. With device off, connect the charger end of the cable to the itouch / ipod but do not plug the usb into the computer.
3. Open Itunes
3. While holding down the menu button (and I mean keep holding it down), plug the usb into the computer.
4. Wait to see the new wonderful graphic on your device and computer screen that shows that your ipod / itouch is recognized.
Your itouch will start immediately restoring itself and you are ready to fill it up with wonderful images, photos and videos again!
So happy to share this tip. It saved me money and time.
on Jun 29, 2010 | Apple iPod touch
I disabled my itouch because i put the password in wrong
If you enter the password too many times it becomes disabled for security reasons. There is not a master code to unlock it. You will need to restore the ipod and reload from your library or from your back up.
Once at the computer you will need itunes open and your ipod connected
1) Make sure you have the latest vertion of itunes downloading
you can check this by going to { HELP>CHECK FOR UPDATES}
2) On the ipod hold the sleep wake button at the top and the home button on the bottom at the same time until you see the apple logo
3) Once you see the apple logo - release the sleep/wake button but remain holding the home button
4) You will see an error message from your computer
5) click ok - Then the restore button - the restore will take about 15- 20 minutes
Note: if you have previously backed up the ipod it will prompt you to restore from back up in the restore process
6) re - sync2_bing.gif your content after the restore is complete
7) after sync disconnect and use
I hoped this helped-
** NOTE: If you get an error while restoring the ipod try and restore from another computer ***
May 21, 2010 | Apple iPod touch
If just says ipod is disabled try again in 4984418
Dec 08, 2009 | Apple iPod touch
My ipod is disabled
While your itouch is connected to your computer, and itunes is open, press and hold the sleep/off button (the one on the top of the itouch) until the slider comes up on the screen. Slide the slider to turn off the itouch. Now, press and hold the home button (the one right below the screen) and at the same time, press the off/sleep button again. Hold both until you see your itunes page bring up a "restore" feature. Unfortunately, when restoring, you will lose all data (songs, etc..) Hopefully, you have this data in itunes and can easily download it back onto your itouch. This is the only thing that works. Sucks that you lose everything, but at least your itouch will once again work....
Jul 22, 2009 | Apple iPod touch
My iPod Touch is disabled/"Powned" and I have no clue how to fix
Your ipod has been jailbrokan and apple has detected that so they disabled it.
Jun 13, 2009 | Apple iPod touch
My itouch is not working
The Ipod becomes disabled if you fail to put the correct code 10 times. Can you restore the ipod? see if that works
Jun 10, 2009 | Apple iPod touch
I bought an itouch 2nd hand and its disabled
Jun 07, 2009 | Apple iPod touch
Ipod itouch disabled
Restar your iPod by Holding the power and home buttons until it turns off. than start it back up by pressing the home button
Aug 01, 2008 | Apple iPod touch
My itouch is disabled and i dont remember my password. i try 2 connect it to my computer thru itunes but it wont show up because it says it is locked.
i had the same problem. this is all the steps needed, calling apple isnt necessary.
first: press down on the top power button and on the menu button
second: keep pressing, eventually the screen to turn it off will pop out. ignore it and keep pressing.
third: the itouch will turn off completely but dont stop pressing
fourth: the apple sign will come out. you may now release.
fifth: now you should be able to connect to itunes that will restore your ipod.
your welcome.
oh and get some ice for your fingers . lol.
Jun 30, 2008 | Apple iPod touch
Apple iPod touch Logo
88 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
