Question about IO Shield Computers & Internet
No boot repeated 1 long beep - IO Shield Computers & Internet
OS Vista. 2 short and 1 long beep repetitive - will not boot at all.
2 short beeps and 1 long beep (repeats 5 times)
Unable to initialize video or video card required but not installed.
if you have a video board add on card, reseat after unplugging power cord.
If built in, time for new computer
Nov 02, 2013 | HP PAVILION A6230N DESKTOP PC
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
Sep 30, 2010 | Intel S6240 Notebook
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
GA-MA790GP-DS4H doesn't boot. It gives 14 short
Hello my friend,
There is no way to have 15 beeps error especially short ones so
First try to count the beeps and if are long or short
Jan 29, 2010 | Gigabyte Computers & Internet
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
thnk you.
Nov 29, 2008 | Computers & Internet
I have an Asus p4s533-mx motherboard which boots and runs fine (sometimes). But when I perform a warm boot, it often won't pass POST. The beep code is one long and two short. If I power it down and let it...
The response from ASUS tech support - It's a standard Award BIOS, so they're the standard beep codes.
So I wrote the following on page 3-4 of my user guide:
1 long + 2 short = Video adaptor error
1 long + 3 short = No video card or bad video RAM
high freq beeps while running = Overheated cpu
repeating high/low = cpu problem
repeating (endless loop) = memory error
Sep 29, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top IO Shield Computers & Internet Experts
David Payne
David Payne
Are you an IO Shield Computer and Internet Expert? Answer questions, earn points and help others
