Question about Kitchen Appliances - Others
Cotton candy machine
I just got a cotton candy machine today and tried it for 3 or 4 minutes and when i turned it off it was not turning on again. how do i fix this?
    Champion:
  • 252 Answers
Sounds like a defective switch, or wire that came off. Inspect wires connections.
I am assuming it is a home use model, then you should return it, they are not repairable.
Posted on Feb 13, 2014
Tip
Be the cotton candy maker!
Here is how to operate a professional cotton candy machine.
First of all make sure you are renting the machine from a reputable company and that it arrives with a trained professional who knows how to operate it properly.
Also make sure that the machine is on a steady base and that no children or animals can get too close.
It is best to use a plug just for the machine instead of sharing it with other appliances.
To begin, turn on the machine's main power switch and fill the floss head with sugar.
It is very important not to fill the head above 90%.
Turn the machine's motor and then the heat switch on, putting the head dial setting on HIGH.
The sugar will start forming in about 45-60 seconds.
When the cotton candy starts pouring out you should have your cone ready. Dip it in the machine and pick the cotton candy by giving the cone a twirl that will gather the sugar around the cone.
Avoid rolling the cone around in circles as it is not the correct method to gather cotton candy.
When you are done, first of all turn off the HEAT and allow the motor to continue running at least 45 seconds, in order to get rid of the leftover sugar, and cool down the heating element.
Than disconnect the stabilizer screen and clips, rinsing them in warm water to dissolve the sugar.
You can now remove the floss pan from the main unit and rinse it off.
Children must not play with the cotton candy machine. It certainly is fun but it is not a toy.
on Dec 26, 2013 | Kitchen Appliances - Others
How do you cancel wash cycle on candy do df 800 the programme is stuck on filling up so have turned water supply off but cannot cancel programme
Good evening Julie
you have problems with your Candy, so have I with mine.it is mostly when I am starting a drying program, that she starts washing again. Then I :
  • turn the machine off
  • Wait 3-5 minutes
  • Turn on emptying
  • Wait 3-5 minutes
  • Turn on spinning
  • Wait 3-5 minutes
Try this way, turning the machine off, waiting and over to the programme you want.
good luck
kolbrun
Aug 12, 2015 | Candy Washing Machines
My candy lights are on but it will not start washing
Douglas
Sometimes I think that those machines have a mind of their own. This certainly applies to my Candy washing machine and my computer.
  • What I do when the lights are on but nothing happens, is that I turn the machine off and wait 3-5 minutes
  • Choose another programme and push the button
  • Usually it starts washing but if not
  • I disconnect the electricity and wait 3-5 minutes
  • If nothing happens then, I give the machine a rest for ca 24 hours and hope for the best.
  • which usually happens
Kolbrun
Jul 25, 2015 | Candy Washing Machines
Help fix cotton candy machine
The lighter wires from the transformer, black attaches to terminal 4, (this will have many other wires attached, and can be more than one terminal labeled #4) The red from transformer attaches to #3, it will be the only wire on a #3 terminal.
The heavier red wire most likely goes thru the back wall to the brushes, and attaches to a #4 terminal also. They have used different heat controls over the years, so this diagram may not exactly match your machine, the the terminal numbers are consistant.
May 17, 2013 | Kitchen Appliances - Others
Cotton candy maker will not power on
If you have checked to make sure it is plugged in, and outlet has power. The next thing to check is a circuit breaker in the front underneath the handle. A small white button to push.
If resetting the breaker, and it runs for a second then trips again, do not reset it again, this indicates a ground fault in the machine and it needs to be repaired by technician.
If the breaker doesn't change the operation (no power) then it should be repaired by a technician as there is no easy fix for the symptoms you have described.
Mar 21, 2013 | Gold Medal Products Gold Medal 3008SS...
Nostalgia electric hard candy cotton candy manual
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here:
http://nostalgiaelectrics.com/manuals/PCM805.pdf
Jun 17, 2012 | Nostalgia Electrics Hard Candy/Sugar Free...
Machine makes loud noise when turned on to spin
I FACED THE SAME PROBLEM . BEST OPTION IS TO GO TO THE STORE FROM WHERE YOU GOT IT DONT TAKE THE RISK OF FIXING IT YOURSELF YOU MAY TURN UP COMPLICATING THE PROBLEM MORE
Feb 19, 2012 | Gold Medal Cotton Candy Machine
I bought a Nostalgia Electrics Cotton Candy maker model number PCM 805, it happend to be the floor display and did not come with instructions. How do I operate this machine?
put it togerther
turn it on
let it heat for 4 minutes
add 2 peices of hard candy
opposite from eachother (like this) ( IoI)
hold cone vertically over and turn slowly
and that is how it works!!!!!
Dec 29, 2010 | Nostalgia Electrics PCM805 Hard CandySugar...
Kitchen Appliances - Others Logo
148 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
