Question about KitchenAid KESA907PSS Electric Kitchen Range
HOW TO REPLACE THE RANGE MEMBRANE SWITCH ON KITCHENAID KESA907PSS00
TURN OFF BOTTON NOT WORKING.I NEED TO TURN IT OFF FROM THE ELECTRIC PANEL
vest6
  • 196 Answers
SOURCE: KERC600GWH1 glass control panel is cracked.
Replacing the Ceramic top is not difficult. Just remember to be careful. There should be 2-to-5 screws holding the top to the front support. Removing these screws will allow the top to be tilted up and back. Depending on the style you may have to remove the burner plates from the top. Remember to disconnect the power before attempting any repair
Posted on Dec 30, 2007
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
  • 221 Answers
SOURCE: PF code on KESC300 Kitchenaid Electric Range
its a power supply problem in your unit .the PF means power failure in the unit. just check out the power cord wire it may be also faulty .or getting cut in between so the required voltage is not been supplied to the unit so its showing this pf on the display.
Posted on Jan 19, 2009
  • 718 Answers
SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
Posted on May 09, 2009
Hello Experts, I NEED some advice to remove the control panel on my Kitchenaid electric range (model KESA907PSS00). I can't seem to get the darn thing off. It's loose @ bottom but will NOT release...
I have owned many mediocre appliances but the KESA907PSS00 is the worst of the lot. The burners turn on if you bump them - a contractor bumped it without knowing and left, a pot with chicken was reduced to charcoal and house filled with smoke when we returned. And burners don't turn on, have replaced three burner controls so far. The front door tempered glass exploded while we were gone one day with oven off. Now the oven will not turn off, have to flip the breaker to shut it down. Though I know it is a Whirlpool at heart, it is my last Kitchen Aid appliance. I will be looking at control panel to replace membrane switch so if you have not solved your problem yet, please advise, might figure it out. Called Kitchen Aid, waste of time. Another Retired Cop
Jan 25, 2011 | KitchenAid KERA807P Electric Kitchen Range
I done baking and try to shut off the oven. The off button doesn't response.
Hello & Welcome to FixYa
As the off button wont respond so the problem is with the membrane switch that is bad and needs replacement. This switch usually comes with the control pnael and to replace it you'll have to buy the control panel. Please get back to me if you have any other questions.
Kevin
Jan 10, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
Have error message F2EO,oven not working
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 21, 2010 | KitchenAid KESC307 Electric Kitchen Range
Display reads EO -F2- stove top works, oven will not
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
I get an F2 E5 error on my panel, what is wrong? the bake does not work.
As per Manual :-
F2 E5 - Cancel key drive line open.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | KitchenAid KERA205P Electric Kitchen Range
Oven controls all work but off buton not working. to shut off we trip the main breaker.how to repair? this is a kitchenaid electric range.model ykesa907.
This is the Membrane switch which is faulty. I had mine replaced once already. These units cannot be repaired, they need to be replaced. Apprently it is very common and you should report this to your local ESA (Electrical saftey authority) this is a very dangerous problem. The ESA can have this item recalled if enough people lodge a complaint. The round Stove top knobs on these Ranges also have a tendency to switch on when bumped, very dangerous too.
Oct 03, 2009 | KitchenAid KERA807P Electric Kitchen Range
Can't turn oven off
Over the 2008 Hoildays while baking, our Kitchenaid range (KGSA906PSS) "off" button would not turn off the gas oven portion of the range. The two ways we could turn off the oven was to either set a "stop cooking" timer for one minute or to go the main electical breaker box and cut off the electricity to the the range - either way- not a good way. We called Kitchenaid Customer Service at 1-800-334-6889 and stated the problem. We were concerned that this was a safety issue since we could not turn off our gas oven without resorting to the timer or breaker methods. The warranty for the electronics touchpad is from 2-5 years according to our owners manual. We have had the range since Aug. 2005.
We provided our model #, serial#, date of purchase and answered some other questions. Kitchenaid did determine this to be a safety issue and in doing so, our replacement part and labor will be provided free of charge.
Even if your warranty has expired, I would still call Kitchenaid first since this is a safety issue.
Dec 03, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KESA907PSS Electric Kitchen Range Logo
53 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
