Question about Samsung DLP HL-P5663W 56" TV
Replace samsung HL61A750A1F lamp - Samsung DLP HL-P5663W 56" TV
No picture
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
Aug 10, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung tv model HL61A750A1F
personally, i would check fan # 3.
Nov 15, 2011 | Samsung Televison & Video
Bulb will not come on . I replaced with new one & still wont come on.
Sounds like the ballast is at issue, If you have the correct lamp for your ballast. Samsungs are very critical that the lamp be matched to the ballast, often replacement lamp dealers dont take that into consideration when substituting samsung lamp numbers. Was the lamp a samsung lamp or a generic replacement?
Jul 20, 2011 | Samsung Televison & Video
MY SAMSUNG HLP5063 HAS SOUND BUT NO PICTURE ON ANY SOURCE OF MEDIA
have you replaced the bulb already this lamp are made to last 6000-8000 life hours and if you have not replaced the lamp yet that would be the first place to start,here is the lamp you need just in case
http://www.discount-merchant.com/Samsung-BP96-00608A-Lamp-Enclosure-p/samsung-bp96-00608-lamp-enc.htm?1=1&CartID=0
Oct 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Lamp and temp lights are blinking
Hi,it could be time to replace the lamp if you are getting the following symptoms : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips if you are around that time frame and havent replaced the lamp it might be time.Found the lamp you need here: http://www.discount-merchant.com/Samsung-bp96-00224c-OEM-Replacement-LAMP-BULB-p/samsung-bp96-00224c-oem.htm?click=48173 and here's instructions to replace it: http://guides.fixyourdlp.com/samsung/bp96-00224.php Good luck and God bless you!
Dec 05, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP HL-P5663W 56" TV Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
