Question about Farberware Rotating Head Knife Sharpener
How to use a farberware knife sharpener
Manual
Can you effectively sharpen a 12in hunting knife with a dremmel? if so How do i do it
Hi Patrick
You CAN, but IMO the dremel would be too aggressive for the job. My grandfather gave me a pocket whetstone many years ago and I use it to sharpen my Leatherman wave tool. Works amazingly well, I can almost shave with it.
(EDIT)
A good reference on how to use a whetstone to sharpen a knife can be found at:
http://www.wikihow.com/Sharpen-a-Pocket-Knife
This particular set of instructions refers to a pocket knife, but the principles involved are the same.
Hope this helps you out.
-Steve
May 13, 2015 | Hunting
Tip
How Do Knife Sharpeners Work?
Knife sharpeners are a way of preserving
knives and other such tools that have become blunt with use and therefore less
effective.
Sharpeners work by grinding the knife
against a hard, rough surface. Usually stone is the most common type of
sharpener but sandpaper (which has a soft surface but is hard), can also be
used.
You can take your knives to a knife shop
where they will sharpen them for you (on average once a year), but if you are a
keen knife user and want to keep your knives sharp and in excellent condition,
it might be worth buying a sharpener of your own.
To sharpen your own knives you’ll need to invest in a good whetstone. These are
stones that are available in fine, medium and coarse grits.
The sharpener will come with
instructions about the angle you need to place the knife at in order to sharpen
it.
You can also buy stones for polishing
and to complete the job properly, after you have sharpened your knife, you
should polish it.
on Dec 25, 2013 | Kitchen Appliances - Others
Is there such thing as a knife that doesn't need sharpening?
There are some new knives on the market called "ceramic knives" that are made out of zirconium (the same stuff as fake diamonds.) They don't get dull because they are are wear resistant and should stay sharp for life. Be advised that ceramic knives are very expensive!
Dec 26, 2013 | Kitchen Appliances - Others
Can you use a knife sharpener on a bread knife?
If you were to use a knife sharpener on a bread knife in short term it might help the dullness issue slightly. However, the longer you use it the duller the grooves will be. A bread knife is a bread knife because of those grooves! My suggestion would be to use the sharpener on a bread knife for a maximum of four or five times. Anything after that would probably widdle down the grooves to the point where you are actually making the knife less effective.
What is a knife guide?
A knife guide is an electronic device placed in knife sharpeners that automatically position the knife, in the right place in the sharpener so it will be perfectly sharpen
Jan 30, 2013 | Measuring Tools & Sensors
What is the edge angle when sharpening a knife?
This is the angle between the blade and the stone.
Jan 24, 2013 | Kitchen Appliances - Others
Do I need to sharpen my knife?
Every time you use your knife, the edge will become slightly less sharp, and you are more likely to injure yourself with a dull blade than a sharp one, as they can slip while you are working. Make sure you buy good knife-sharpening steel and use it each time before cutting with your knife it will also prolong your knife.
Jul 25, 2012 | Camping, Backpacking & Hiking
How to sharpen the blades on my Swiss army knife?
You can sharpen your Swiss Army Knife is using a circular motion. Start by holding the blade away from you at the proper angle. Run the blade of your Swiss Army Knife in a clockwise motion on the stone until you have sharpened that side of the blade. Turn the blade over and repeat with a counter clockwise motion.
Jul 09, 2012 | Camping, Backpacking & Hiking
I need the instruction manual for using the Chef's Choice 300 knife sharpener please.
I could not find a complete instruction manual online for your product, but here are some links from the EDGECRAFT ONLINE SUPPORT page for your model:
http://www.edgecraft.com/page2a_m320.html
http://www.edgecraft.com/faq320.html
http://www.edgecraft.com/tips_qrfelec.html
Good luck, hope this helps a bit.
Apr 21, 2011 | Chef's Choice Flex HoneStrop Knife...
Farberware Rotating Head Knife Sharpener Logo
443 people viewed this question
Top Farberware Home Experts
john h
Tom Chichester
Are you a Farberware Home Expert? Answer questions, earn points and help others
