Question about Texas Instruments Brightboxe Dlp Projector
Won't turn on or complete charging. Worked for about 1hour before failing
On charge all night without charge completion. Won't turn on at all.
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
Ijustbought a newbattey for my acer aspire 6920 laptop. Iinstalled it and it said 61% available, I let it charge all night and all day untiljust now 7pm. and id still says 61% and charging . the old one...
First try a REFRESH by discharging it COMPLETELY than re-charging it COMPLETELY (do that 4-6 times) nice week end project ha!, than if it still won't charge completely ASK FOR A REPLACEMENT OR REFUND... (if it's new it should be under waranty)
May 26, 2011 | Computers & Internet
Do I have to charge up the battery on my new Acer 531 before I set up and use. If so - for how long? Thanks
its best to drain the battery completely in it, before you go near it with a charger. then leave it charging over night a good 12 hours will give it best life. each time then only charge it when its empty. if your using your laptop at home, take the battery out and put it away saves it been charged and charged for no reason. doubles its life
Dec 03, 2009 | Acer Aspire 5610-4648 Notebook
Battery fails to charge completely
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Nov 02, 2008 | Gateway CX200S Tablet PC
Battery charge
I called Kodak last night, they told me to turn the camera off, then remove the batteries and the memory card then wait ten seconds then reinstall both. Then turn the camera back on.... IT WORKED~ try it!!
Dec 01, 2007 | Kodak EasyShare CX7530 Digital Camera
Help my screen is white!
Did you try taking the battery out for a couple minutes, putting it back in, and trying again?
Aug 18, 2007 | Motorola Mobility RAZR V3c Cellular Phone
IPaq rx3115
I had a similar experience. My device would not charge via the usb charger so I connected it to my wall charger and it charged successfully.
Jul 07, 2007 | HP iPAQ RX3115 Pocket PC
Texas Instruments Brightboxe Dlp Projector Logo
24 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
