Question about Soleus Air LX-100 10,000 BTU Evaporative Portable Air Conditioner 980W, 120V uses eco-friendly R-410A refrigerant
How do I charge the refrigerant on my soleus air LX 100?
  • 90 Answers
I think that operation it is a proffesional operation with many proffesional tools,and you can not do this alone(pice and tehnical)
Posted on Dec 29, 2013
Where is the fuse located on my soleus air conditioner lx-140 house unit. I want to replace it.
PDF]download manual - SoleusAir
www.soleusair.com/Manuals/2013%20Manuals/.../PH4-13R-01_Manual...
Thank you for choosing a Soleus Air Portable Air Conditioner with Heat Pump ... owner's manual will provide you with valuable information necessary for the
Aug 17, 2015 | Soleus Heating & Cooling
Can a SoleUSAIR be recharged
Yes they can be. But what makes you think that it is low on a charge of R410A?
Jul 01, 2014 | Soleus LX-140 Portable Air Conditioner
Soleairus recharge
14 oz if completely empty. yes it can be charged but what caused it to be low in the first place? refrigerant dose not deplete so a leak is what i would be looking for you need to fix it first you don't wont contaminants like air in the system.
My soleus air LX 100 is blowing cool air while its in heating mode why? I'm freezing during these winter storms help
at first see i think is necesary to complete your refrigerantor your inverter have electronic problem.
Dec 26, 2013 | Heating & Cooling
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Condenser not working
Actually, the compressor has to be running to get cool air. Your unit may have lost Freon while in storage.
Sep 15, 2012 | Soleus LX-100 Portable Air Conditioner
The plastic for the duct work melts. Do you have any solutions?
You mean that it melted right, not that it's actively melts with the unit running? Epoxy is a potential solution. Depending on the location, you can use a liquid or solid epoxy. Epoxy comes in 2 parts, use equal amounts and mix them thoroughly before applying.
Jul 16, 2011 | Soleus LX-100 Portable Air Conditioner
Have a Soleus LX-140 portable air conditioner. Water was leaking out the right side of the machine. Opened the casing and found a clear hose, one end attached to the plastic tray above the condenser and...
I have an LX-100, and had the same problem, so I am guessing that the designs are similar. There should be a pump in the condensate pan at the bottom of the unit -- on mine, it was near the front, right next to the overflow float switch. There should be an outlet on top of the pump, which is where the hose needs to be attached.
It looks like the pump pushes condensate up into that plastic tray, which lets if flow over the heat exchanger, both cooling it and evaporating the water. With the hose detached, you're probably noticing degraded cooling performance and a lot more condensate in the holding tank than there should be. At least, that was the case for me. Good luck.
Jul 05, 2011 | Soleus LX-140 Portable Air Conditioner
Cannot turn on.
Since you have power to the clock display- there is power to the unit. The "power" function button has failed because the momentary switch on the circuit board below the touch pad has failed. These little push switches have a short service life.
I suggest checking a source who sells the control circuit board for Soleus Air LX-140. Might be similiar component.
KT
Jul 30, 2010 | Soleus LX-120 Air Conditioner
Soleus air heat pump soleus lx 140 quit working
Hi
The Soleus Air condenser blower wheel is all plastic and I have seen many of them disintegrate from normal residential use. It's just a weak part.
Go to shop.soleusparts.com and buy a metal blower wheel replacement kit. Problem solved!
May 19, 2009 | Soleus LX-140 Portable Air Conditioner
Soleus Air LX-100 10,000 BTU Evaporative Portable Air Conditioner 980W, 120V uses eco-friendly R-410A refrigerant Logo
111 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
