Not heating just had my 2004 hyundai elantra gt fixed from a oil leak and blown gasket and ever since then i have been having problems with my heater its not heating no more.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Check heater hoses may be mechanic disconected them.Usually they trick customers to come back to work shop for more extra charges to the customer.
Posted on Jan 05, 2014
Burning smell oil
Have you checked for oil leaks? Valve cover gasket or gaskets if a V6 would be the most common oil leak. Only with heat or have you tried with a/c ?
Apr 09, 2014 | 2004 Dodge Stratus
Overheated now won t start
Do a compression test or cylinder leakage test to check if the head gasket is blown. Looks like it blew on the water side. Or it could be that it overheated so badly that it could have collapsed the rings.. But if its not turning over means water got into the cylinders and seized up the piston. Remove the plugs and have a looks with bore scope for water ingress
Apr 06, 2014 | 2004 Hyundai Elantra
Hyndai Elantra 2004 coolant resoirvoir blew up and need inst. on replacement.
You can find replacements at any autoparts store. I wouldn't recommend driving your vehicle until you have this excessive heat will eventually blow a head gasket which which will cost a lot more money.
Mar 29, 2013 | Hyundai 2004 Elantra GT
Antifreeze in oil on 05 elantra
You have a blown engine cylinder head gasket most likely.
Jun 14, 2012 | 2005 Hyundai Elantra
I have no heat in my 2004 hyundai elantra..turn it on and nothing
Check for a blown fuse. If there is no blown fuse then I woudl replace the heater fan relay.
Dec 15, 2010 | 2004 Hyundai Elantra
Lost oil suddenly while driving on highway.... what could have happened? 2004 Hyundai Elantra.... 53500 miles
Dont ask me, I m not there to look??? ck the oil filter . maybe jiffy lube didnt put it on right, or check the drain plug. ck oil sender switch. Fill it up and see where the leak is.
Apr 24, 2010 | 2004 Hyundai Elantra
I have a 1995 Hyundai elantra 5 spd 1.6L 4cyl leaking oil
It maybe a valve cover leak, the retangular covers (2) the sparks plugs are located along the side, if you see oil around you will need to have the valve cover gasket replaced
Oct 28, 2009 | 1995 Hyundai Elantra
2004 hyundai elantra that surges violently 1000 rpm to 4000 rpm
could be afew things. vacuum leak, one dud HT lead, could be the water temperature sensor, O2 sensor, best to get it checked and get it read for fault codes
Sep 03, 2009 | 2004 Hyundai Elantra
Overheating it gave no indication until all the sudden it pegged on hot. there is no leaks ,no warning lights nothing. to get home i kept having to stop and let it cool then some times i had to add water...
check ur oil and see if milkey gray or white in color if so u have bad engine problems the least a head gasket blown the worst the head is cracked and or warped,,, replace every thing to do with cooling when repaired,u dont know what caused it.
Jul 03, 2009 | 2004 Hyundai Elantra
Axle leak
This sounds like it could be either the C/V (constant velocity) joint boot cracked and oozing grease, or the axle seal on the transmission could be damaged. If just for peace of mind, have this checked out as soon as possible. These are not costly repairs, now, but if delayed they could be VERY costly. Anything transmission related should be checked ASAP.
Nov 12, 2008 | 2004 Hyundai Elantra
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
