Question about Dryers
Dryer is control locked, will not start. How do I release it?
Model # feq1442esi
  • Dryers Master
  • 8,220 Answers
Try the Pause/Cancel button
Posted on Dec 26, 2013
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Control locked light is on. Have replaced control board but control still locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
May 28, 2015 | Whirlpool GEW9250 Electric Dryer
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
My dryer says (loc) and will not start
  • Hold the "Control Lock" button, located in the bottom corner of the controls, for five seconds.
  • Release the button when the small LED beside the button lights up. Hold "Control Lock" for a further five seconds to cancel.
  • Nov 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
    please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
      1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
      2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
      3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
      4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
      5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
    Dec 24, 2010 | Dryers
    Where is the resset buton on frigidaire electric dryer machine?
    1. Press and hold the "Control Lock" button for five seconds to lock the dryer. Release the button when the dryer beeps, indicating that the dryer is in locked position.
    2. Press and hold the "Control Lock" button for five seconds to release the lock.
    3. Press and hold the "Options" and "Select" buttons at the same time on Frigidaire dryer models that do not have a "Control Lock" button. Hold the buttons for 10 seconds until "LOC" is displayed.
    4. Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.
    5. please comment on these by telling how helpful.
    Dec 20, 2010 | Frigidaire Electric Dryer
    Dryer stops when I release push to start button
    Timer may need to be replaced. You can test it with an ohmmeter or test light.
    You can do the same with the push button. If you have more problems, then the main control could be faulty
    Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
    I have a whirlpool duet dryer - the control lock button is engaged - I've held down the end of cycle button for three seconds + plus it will not release. What next?
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jun 13, 2009 | Whirlpool ET8CHEXSQ Dryer
    Control locked on, can't release it
    find button with lock emblem hold 3-5 secs if will not clear suspect either bad interface(buttons ) or bad connection or broken wire between front panel and interconnect on main control
    Nov 26, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    Top Dryers Experts
