Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Clutch replacement for chevy extended cab 4 wheeldrive 1995
Missing 1st gear and third gear
  • 43 Answers
Clutch replacement for chevy extended cab 4 wheeldrive 1995Missing 1st gear and third gear what are you talking about
Posted on Jan 05, 2014
No 1st and 2nd gear and no 5th or reverse gear what can be the problem
automatic or manual gearbox
auto
if third gear is there transmission computer module in fail safe
torque converter
solenoid failures
other internal failure
if manual
clutch
gearshift cables or
internal failure of gearbox
Oct 26, 2016 | Cars & Trucks
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
1995 chevy regular cab 4.3l v6 2wd wont go into overdrive
Sounds like it is stuck in second gear. Overdrive only drops rpm by a couple hundred. In third gears you should still be less than 3,000 rpm.
Second gear is a default gear when the transmission is in limp mode. Is the check engine light on? Does it shift if you manual shift through the gears with the gear selector?
Sep 21, 2014 | 1995 Chevrolet C1500
1995 chevy cavalier transmission kills the engine when put in gear
Replace the Torque Converter Switch
Your trans is working like a standard shift,
when you forget to put the clutch in at a stop
Mar 16, 2013 | 1995 Chevrolet Cavalier
My 1995 f-150 automatic will shift from 1st to 2nd fine but does not want to shift into third. Is this an electronic problem or possible internal wear? It has also been using auto trans fluid. Tonight I...
It depends it could be a bad servo for the 3rd gear trans or it could be that 3rd gear clutch is worn out
Only way to sepearte these problems is to have the trans pressure tested and distinguish the problems
Sep 24, 2009 | 1995 Ford F150 Styleside Regular Cab
Rebuilding 1995 honda civic transmission
Did you make sure that the tork converter was all the way forward first if not then you will need to take the transmission back out and make sure that the converter has either automatic trany fluid in it or 184/85 gear oil depending on whether or not you have automatic trasmission or manual fill it up until you can put your finger in it and then rotate converter clock wise and it should slip into place before putting trasmission back into car and if after doing that and you still are having trouble take it to a transmission shop to have them do it for you.
Sep 14, 2009 | 1995 Honda Civic
1995 Sabb 900 clutch wont engege in reverse
Bad syncro for third gear. Sorry, but you aren't fixing this one yourself, unless you replace the transmission yourself.
Sep 14, 2009 | 1995 Saab 900
Low power
have you checked for a clogged fuel filter or a vacuum leak.
Aug 30, 2009 | 1995 Ford Ranger Supercab
1995 chevy not going into reverse
check link to trans to see if is working when you select it to reverse are could be trans pump in the trans may need to rebuild the trans
Jan 21, 2009 | 1995 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
