Question about LG 42LG30 42 in. LCD HDTV
Usb port how do you use it
I tried a usb cable in the back of my 42lg30 but it didnt regester and the owners manuel said its a service port what does that mean and how can i use it would like to connect my laptop to tv
  • kennyj6 May 17, 2009
    thank you
  • 696 Answers
By service port they mean a device hookup that a tech can use to diagnose problems with your TV. There is no practical use for you to plug into it. If you want to display your laptop on the TV you need yo hookup the video out from your laptop to the TV's PC/RGB input.
Hope this helps FixYa,
Chris
Posted on May 17, 2009
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
The hdd is not recognized by the pc, evrytime i plug in the hdd it ask me to formated
Are you using EXTERNAL HARD DRIVE, which means the hard drive is in a box, and you connect it to computer with USB cable? If so, do the following
1. Try to plug and unplug and plug USB cable at the port on computer. 2. While plugged in, try to shake the plug a little. 3. Try to plug the USB cable to USB port at the back of the PC case, not the port at the front 4. Check the usb cable, buy a new one, or borrow one (its cheap) 5. Still does work? bring it to Customer service, there must be an error on the box itself.
Mar 25, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My sylvania smpk4600 mp3 player won't turn on, it only works if it is connected to my computer via the usb cable.
I had the same trouble I noticed that it acted differently on different usb ports strange but it happened, swap to a different port, if the battery animation isnt moving that it hasnt synced properly i noticed that it especially didnt like working with my front panel usb ports, switched it around tot he back and it charged just fine
Mar 21, 2011 | Audio Players & Recorders
I have an Olevia 42" LCD with the same problem
there rs232 to usb cable converter, you just buy it, and you got rs232 to usb connetor
Jan 11, 2011 | Olevia LT42HVi 42 in. LCD Television
My notebook currently not recognized my 500GB Buffalo external hard drive. I dont want to reformat it because few important files are still in it (i didnt back up anywhere else) and i need them badly at...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Buffalo Technology (USA), INC. - 500GB...
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
I've bought a USB 3RCA data cable to project video from my Laptop to me TV/projector. However it doesn't work, and no signal appears to be received by either TV or Projectors... USB 3RCA Cable from PC...
i hope that is a USB driver issue when u plug your device does your computer detect any usb device and then its says unknown/unrecoginzed device. You have to check the cables first then you download USB2.0 driver install it inyour computer andl aslo try to connect the device in another port also put the the driver cd for the TV/projector
Jul 02, 2008 | Computers & Internet
LG 42LG30 42 in. LCD HDTV Logo
1,059 people viewed this question
Computer Repairing
Computer Repairing
