Question about Nuvico NVDV3-16000N
Need to delete recording - Nuvico NVDV3-16000N
Recover deleted history
Hi there Kaci, my name is Kimberly and I form part of the Social Media department with DISH. I am sorry to hear you accidentally deleted your recordings. It is my pleasure to help you. Recovering your recording would depend on the type of receiver you have. If you currently have a Hopper system, under the 'My Recordings' tab select 'Deleted Recordings' once you are in the Deleted Recordings folder simply select 'Restore'. For any other model of receiver unfortunately this option is not available, meaning your recordings have been permanently deleted. If you have additional questions or need assistance with your DISH service, feel free to reach me at: kimberly.escobar@dish.com
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Jan 21, 2014 | DISH Network Televison & Video
I cant delete voice recordings off my LG KU990 as there is no option anywhere so what do i do? i realllly need to delete it urgently .
You can delete your voice recording by doing the following.
1.After you have finished recording,
2.touch the button having 3 lines on the screen and choose Send, Rename, Delete, Use as (to use the recording as your ringtone) or Go to my sounds
3.select delete and confirm that you want to delete the file.
Hope this helped you? Please comment for more information and thank you for using fixya.
Jan 18, 2011 | LG KU990 Viewty
My pantech ease says that the memory is full and to delete messages, but I deleted all my messages. How do i fix it?
This phone easily records conversations. Check in your audio then go to voice recordings. I guarantee you have accidently recorded a conversation and it wiped out your memory. I had this problem and finally figured out what was causing this. Just delete it the recorded conversation and you will be fine!
Oct 08, 2010 | Pantech Cell Phones
Can you recover deleted files from the Olympus Recorder VN-4100PC? also, one of my files is unable to play. any way of recovering it?
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
Sep 01, 2010 | Olympus VN-4100PC Digital Voice Recorder
Recover deleted files from cenix vr-p3490
You can recover deleted files with asoftech data recovery software. get the software from link below
Audio Recorder Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
Apr 22, 2010 | Panasonic RR-QR150 Digital Voice Recorder
I deleted seven voice files off my Olympus DS-2300 and need them back! Can they be restored or retrieved?
Yes, those voice recordings can be recovered provided not overwritten(if you keep taken more records, then possible). The best way is to try some audio recovery software. Here are some for your option. Both programs can also recover videos and photos.
Photo Audio Video Recovery Software (for Windows)
Mac Photo Audio Video Recovery Software (for Mac OS X)
Note: Before your audios are recovered, do not attempt to save more files.
Nov 10, 2009 | Olympus DS-2300 Digital Voice Recorder
When deleting a film previously recorded on my Sony DVD recorder the amount of available space shows 650k as opposed to 800k despite the fact that I have no other recordings held. Can you explain why this...
Jim, Although you have deleted the recording the DVD recorder still sees that space as have been being used. The space should be reusable however the area has been used before (therefore not considered unused space).  By deleting the recording you should have no problem going over the area when it is needed.  Happy Recording Rob
Feb 27, 2009 | Televison & Video
Olympus ds-30 deleted file recovery
on your computer, you will need some sort of media recovery software. also go to options under the tools menu and uncheck delete after transfer to turn off deletion. this is usually best since you can delete the files through the recorder by the erase button
Sep 26, 2008 | Olympus DS-30 Digital Voice Recorder
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
Jan 08, 2008 | Centon Electronics MP4-001 MP3 Player
Nuvico NVDV3-16000N Logo
29 people viewed this question
Top Nuvico Televison & Video Experts
Electro Med Services...
Are you a Nuvico Televison and Video Expert? Answer questions, earn points and help others
