I have a dell intel inspiron 15-3521-i15RV-6190BLKwindows 8 4gb Product ID# 00179-60605-7814-AAOEM Serial ATA I need to find out how to take the back of my PC off so I can clean the fan , how do I
My boyfriend tried to take the back off about two weeks ago but said he couldn`t figure out how to do it so he left it alone. I need help
    Filmmaker:
    Uploaded 5 video answers.
  • 66 Answers
Personally, I would not take the back off of it. I would buy a can of compressed air and blow it out instead. Taking the back off may void the warranty.
Posted on Dec 26, 2013
4 Suggested Answers
blh31280
  • 39 Answers
SOURCE: dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Posted on Nov 08, 2009
Geekman
  • 32281 Answers
SOURCE: inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Feb 22, 2010
SOURCE: Accesing the fan on a Dell Inspiron 1501
Here is Dell's support page on getting to the fan:
http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/fans.htm#wp1000550
Posted on May 02, 2010
How can i fix error code 2000-01 42 Validation 51532 Msg: Hard Drive 0 - S/N WD-WXM1A61M4533
Dustin Larmore,
The error means that the hard drive is defective or broken You will need to have it replaced.
The Inspiron N4110 / N4120 / 14R system uses Serial-ATA II(SATA II) hard drives.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 01, 2014 | Dell factory recertified inspiron...
Trackpad jumping around
Go to control panel and then go to mouse setting to reduce the mouse speed. If the problem still persist then you may can download and re install the fresh drive.
Oct 02, 2013 | Dell Inspiron i15RV-3763BLK Notebook...
Serial ata controller is flagged in device manager
The first thing to try is open Device Manager and uninstall the existing driver for serial ata (SATA) controller. Afterwards, use the Drivers and Utilities CD that you received from Dell to install the Chipset driver depending on the model of your Dell computer. Alternatively, you can go to htttp://support.dell.com and click the Drivers Home link. Enter the 7-digit alphanumeric service tag of your computer , click Continue. Select the operating system version you have, then download the main Chipset driver for your computer. Install it after the download. In addition, check for the Serial ATA category on the drivers page and download the Intel Matrix Storage Manager if available for your computer. Feel free to let us know how it goes.
Feb 14, 2011 | Dell Serial ATA Controller
Recomended hard drive for ispiron 1525
My system shipped with a 160GB, Serial Ata 9.5, 5.4K, SA160, 10 months later the HDD died, Dell replaced it with a 160G, Serial Ata 9.5, 5.4, SE080.
Sep 22, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 530 not recognizing HL-DT-ST-DVD+-RW GSA-H73N ATA. Downloaded latest driver. No luck. Code 10 error.
I'd try rolling back to the previous driver, maybe your machine isn't compatible with the latest driver ...
Nov 04, 2009 | Dell Inspiron 530 -Intel® Pentium®...
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Is this hard drive sata or ide
    It is SATA - Serial ATA (DELL Dimension 4700)
    Jan 17, 2009 | Dell Dimension 4700 PC Desktop
    Dell Inspiron E1505 won't boot
    Try this site to look for hard drives. Not just any drive will work, so make sure you confirm with the company's sales or tech support to make sure it'll work.
    LINK
    Dec 11, 2008 | Hitachi Travelstar 5K100 HTS541060G9SA00...
    Computers & Internet Logo
    David Payne
    David Payne
