Question about Velocity Micro Cruz Reader R101 Tablet PC
Extra battery for a Tesoar Tablet - Velocity Micro Cruz Reader R101 Tablet PC
I have my grandaughter tesoar tablet is frozen on the white screen with tesoar across the screen i need help
Hi, you need to do a factory reset!
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
let me know how you get on!
Oct 18, 2014 | Tablets & eReaders
Tesoar tablet freezing on tesoar screen
Try this:
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
May 17, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
How do you fix a frozen tesoar tablet
Press the reset button hole with a pin first.
If that doesnt work then go into recovery mode usually by pressing the power button and volume up buttons at the same time then selecting restore tablet option.
If you tablet is corrupt you will have to sideload or reinstall the os from a usb stick.
May 10, 2014 | Tablets & eReaders
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Mar 21, 2014 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
I have a 7" Tesoar tablet and it worked great for a while and now the only thing it will do is turn off and on. When it's on it stays stuck on the white Tesoar screen.. Can I reset somehow? It will not let...
If a factory reset to default won't work, which it looks like it won't, I think one course of action is to open the back, disconnect the LI-ON battery, (it probably has a small, delicate three pin micro plug, so care is the operative word!), wait about 10 seconds or so, then reconnect it, and see if it then powers up properly.
That is what I did with my T310 when it went into a state of limbo.
Word of caution, opening the back will more than likely invalidate any warranty you have.
Mar 04, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
Download manual for my tesoar tablet
Hello, I am looking for a Tesoar Manual too - were you lucky in finding one?
Dec 01, 2013 | Tablets & eReaders
Tesoar tablet manual
need a manual for my tesoar tablet pc 8gb 4.0 android
Nov 24, 2013 | Tablets & eReaders
Velocity Micro Cruz Reader R101 Tablet PC Logo
47 people viewed this question
Top Velocity Tablets & eReaders Experts
steve morris
steve morris
fred capra
fred capra
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
