Question about JVC KD-G200 CD Player
We are trying to remove a JVC KD-S595 stereo from the car. We have the keys from the new unit (also JVC) we wish to install but they don't seem to fit to remove the old unit. Any help appreciated. thanks
KaeZoo
  • 156 Answers
SOURCE: JVC KD-G720 car stereo - how to change the time?
Press and hold the SEL button to bring up the settings menu. Press and release the tuning (>>>) buttons until you see CLOCK H. Turn the volume knob to select the hour. If necessary, press (>>>) for CLOCK M; adjust the minutes setting with the volume knob. Press SEL when you're finished. An owner's manual can be downloaded from JVC at this link: http://books.jvcservice.com/booklist.asp?Model=KD-G720J
Posted on Mar 15, 2007
informatica
  • 1114 Answers
SOURCE: JVC KD-G430 problem setting the time
You can download the manual from the link below: http://books.jvcservice.com/booklist.asp?Model=KD-G430 The time setting is on page 13. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 21, 2007
  • 341 Answers
SOURCE: How to install JVC KD-G396
Here is the manual.
http://www.jvc-australia.com/JVCstores/PRODUCTS/357/ATTRFILE_File3/KD-G245-396%20Inst.pdf
Posted on Dec 20, 2008
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
  • 13 Answers
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Posted on Apr 22, 2009
JVC KD-S595 car stereo. Trouble removing
It depends what kind of car it's installed into and the mounting technique used. Removal keys apply only to a radio that has been DIN mounted (ie: metal sleeve utilized). Many vehicles or radio kits use the ISO mounting method which involves screwing into the sides of the radio to secure it. Keys will not help in this situation. The dash or radio trim must be removed to access the screws on the sides.
With the front trim of the JVC removed, you should be able to see the metal sleeve around the radio if it was used. If not, the radio was ISO mounted.
Dec 26, 2013 | Car Audio & Video
How do i take this out to install my subs
Your new stereo comes with stereo removal keys. They are the small pices of alominum that are about 3.5-4 inches long.. They insert on each side of your radio. If you don't have them then you must remove the section of the dash under the radio.
May 14, 2012 | JVC KD-G120 CD Player
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
Sep 27, 2011 | JVC AM FM CD DET FACE CAR STEREO
Hello, I have a JVC KD-S33, and I just hooked up the interface on the back of my stereo. I can't figure out how to set the stereo to play my ipod touch. The manual seems like chineese to me. The manual...
You can download the detailed user manual for your JVC KD-S33 in English from the following link.Please refer pages 18 and 19 of the pdf document for doubts regarding connecting the iPod touch with the stereo.( http://dl.owneriq.net/8/8abcc36e-cf2e-4b5a-a002-e343f1ffb6bc.pdf ).Please don't forget to rate me if you are satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 17, 2011 | JVC KD-G200 CD Player
How do I remove the JVC KD-G635 car stereo to gain access to the rear of the unit.
u need special tools to remove the head unit if it was installed right. security purposes
Mar 19, 2011 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
Unit will not turn on
This seems like you have accidently rewired part of your electrics. You may have wired the power wire into the wrong place, and also wired your electric door locks into your accessories. YOU NEED TO BACKTRACK. Find you doorlock wiring and get it back to a constant power supply. Best bet is to wire your power wire of unit to cigarette lighter by splicing the wires or jacking the outlet at the back. Here is a guide to install your stereo. Following those steps and see if you went wrong somewhere.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 18, 2008 | JVC KD-G230 CD Player
Car stero clock
http://www.free-service-manuals.com/cgi-bin/search.cgi?query=KD-S595&action=results
There's your manual. It's a 2.6 mb download, and handy to have.
May 12, 2007 | JVC KD-G200 CD Player
Installing sirius reciever manual
what kind of sirius reciever, JVC, Kenwood, Pioneer? is it ran through a FM modulator?
basiclly i need more info on the sirius unit
Thx,
Don
Feb 27, 2007 | JVC Sirius KD-LH300 CD Player
JVC KD-G200 CD Player Logo
87 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
