Question about Dryers
Elecrtic dryer spins but no heat on any of the settings
  • Doug Boyle
    Doug Boyle May 17, 2009
    No need to look for a TCO or hi-temp thermostat?
  • Anonymous May 18, 2009
    Thank you, that makes sense. I'll check the breakers. Meanwhile, I've got the back off and tested with my multi-tester and got a .01 on the TCO (continuity), if this is located on the exhaust side. I got nothing on the thermostat (in any combination of the four wires). Going to the heating side I got .10 on the lower heating element (I think). And then there is what looks to be another heating element on the high side (are there two heating elements?) where I don't remember what I got....
    Scholar:
  • 42 Answers
Ah -- I've seen this before.
Your dryer wants 240 volts to operate. That would be two 120 volt sources, 180 degrees out of phase. Two 120 volt sources = two circuit breakers.
If one of those 120 volt sources is not working then the dryer will spin but no heat.
Put the dryer dial or switches in the OFF position. Go to the circuit breaker box and find the dryer breakers. There will be two breakers -- ganged (fastened) together. Now, if one of those breakers has blown, and the other hasn't, the 'ganging' will prevent the blown breaker from appearing obvious.
Turn the breaker(s) OFF, count to three and a half then turn them ON with a nice solid snap.
Go upstairs and try the dryer again.
There are other problems that can cause this, but this solution will take care of most of these problems.
I wouldn't worry about the popped breaker unless it starts to happen all the time -- but a one-off breaker pop on a dryer is not a big deal.
Posted on May 18, 2009
    President:
  • 2,976 Answers
You need to replace the heat element. It's a relatively easy & inexpensive repair, using only basic hand tools.
DISCONNECT THE ELECTRICTRICITY BEFORE YOU START
Posted on May 17, 2009
Can you convert the gas model to electrical? I just got a gas model from a friend but have no way to use it.
Sorry their is no way to do that..the gas dryer is only equipped to heat by gas and has no elecrtic heat element in it
Sep 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The dryer willheat real good for about 15 minutes then will only blow cold air. w3hat might the problem be?
is it heated by gas? or electric
if by gas the gas coils coils will operate fine while coll and as they heat up the will not open the gas valve coil
if elecrtic sound as if a restriction in the vent system causing the high limit thermostst to cut out till its cool again before it resets
Jul 19, 2011 | Kenmore 63942 Dryer
Kenmore Elite elecrtical dryer want heat up. Probably needs a new element' error message is "PF".
PF indicates a power failure while unit was running.
Press "Hold To Start" to continue the cycle or
Press Off / Pause to clear the display.
I hope this helps a little.
Jul 17, 2011 | Kenmore Dryers
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
Maytag Neptune Gas Dryer will not spin when turned on. Drum spins by hand. Makes a buzzing noise and elecrtical (burning) smell. Dryer is unplugged now and vent is clear.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Elecrtic kenmore dryer; auto dry setting not working propeely
you just might need a clean out,unplug the dryer take out the filter,remove the bottom panel and remove the duct that the filter slides into,clean it out and vac out the inside of dryer,if you have a shop vac that blows on the other end blow the lint forward so you don't have to pull the drum to clean the inside,make sure you blow off the motor alot of lint gets stuck inside the motor,now go to the back and remove the vent line,if it's a long run i use a leaf blower to blow all the lint out of the vent line,first make sure nothing is blocking the outside vent so when you blow out the line the lint is free to exit outside,all the thermostats run off of heat and if the dryer is blocked and the air can't move it will run hotter than normal,the timer can't opperate correctly either.all this will cost you is time and this should be done once a year anyway
Feb 14, 2010 | Kenmore Elite HE4 Electric Dryer
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Won't Heat -Maytag Gas Dryer Model MD-4 Intellidryer
Once I paid my gas bill--mine started working normally again.
Jan 30, 2008 | Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
