Question about Ryobi Cultivator
Gas shoots out side of carburator when priming?
    President:
  • 2,976 Answers
If it's coming from the primer bulb, replace the bulb. If it's running out the carburator, take iff the air filter and check for obstructions. 2 - 3 pumps is all it should need.
Posted on May 17, 2009
Carburator, only one side is shooting gas into barrel
the hole unit is a throtal body the two bells you refer to are called fuel injecters if i am following you correctlydo they have two wires to each one if so then injectors.
May 19, 2012 | 1991 Oldsmobile Silhouette
Gas shooting out of rubber hose above carburator. craftsman lt200 with kohler engine.
If hose coming off carburator does not connect to anything then it is the over flow for carburator when float gets stuck and does not close needle valve causing excess fuel in carburator bowl and is drained automatically through vent orfice connected to hose that gas is dripping from. If this is the case then remove carburator bowl, check float, needle valve and o-ring in where needle valve goes. sometimes when carburators sit over winter with gas in them the gas breaks down and over time will gel/harden and cause float to hang up and o-ring for needle valve to deteriate and not sealing properly. clean and replace parts as nessesary.
I hope this helped.
Oct 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Very hard to start, i pull and pull and pull on the cord but it wont start i do prime it every third pull any ideas?
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can agitate it do so to help the gas disolve any clogs.
Clean the ports with the spray cleaners to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 07, 2011 | Ryobi Garden
Mower starts after priming, then quits. new sparkplug, air filter etc. cleaned bowl still no luck. cleaned out orifices in bowl screw. nothing. Suggestions?
Evan though you cleaned the bowl, the float isn't "floating" correct in the bowl to raise the needle for gas to flow into the carb. The float and needle can be replaced. When you prime an engine the gas shoots straight to the carb. As when the engine is running the floating goes up and down to raise the needle for gas to flow.
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
Mowers is not getting gas
Check your float ... it might be sticking in the upward position when the fuel well fully fills? This would cause the mower to run on the fuel that gets inside the line when you prime it, but since the float stuck in the upward position would close the intake line from the gas tank, your mower would die after the priming fuel is spent.
[The float is located inside the metal bowl beneath the carburator usually, and can be opened by removing a single bolt/screw in the center of the bottom of the bowl. Be careful to pay attention to how the valve-pin attached to the float is attached; usually it's just hooked on very loosely. Thouroughly clean the float, pin & inside of the bowl, then reassemble after making sure the float moves freely.] If the problem isn't solved by this, you might have an obstruction (like a leaf-cutter wasp nest) in your fuel line between the gas tank & carburator? Check the float first.
Apr 11, 2009 | Mtd 22" Yard Machine Push Mower
RAN OUT OF GAS AND I CAN'T GET IT TO START AGAIN for a 2006 Lexus 250 is keyless start
have you primed the gas convertor?
there is a button on the side of it
Mar 14, 2009 | 2006 Lexus Is 300
Ryobi Cultivator Logo
143 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
