Question about Sewing Machines
Reverse sewing lever
How do i release the reverse sewing lever on a brother lx2375?
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
Australian S
  • 46 Answers
SOURCE: Sewing machine sews only in reverse.
To all the people with this problem. What has happened is the reverse mechanism has stuck, this is often due to not being used for a while or the machine has not been oiled properly, which is hard to do for a user as you virtually have to remove all the covers.
If this particular machine has a screw on cover at the end where the handwheel is, remove it and look inside, you will see the mechanism, what you need to do is push it back out, then oil it but make sure you work the reverse button in and out while you oil it and check it works freely, then just refit the end cover.
Posted on Jul 02, 2009
mohammed387
  • 1952 Answers
SOURCE: lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Posted on Jul 26, 2009
SOURCE: Reverse Lever isn't working...
Most likely the "dogs" inside the lever are broken off. Oil/grease on the metal rod cause chemical attack to the plastic lever and the "dogs" break. Singer should know to degrease this rod before assembly.
Posted on Nov 06, 2009
SOURCE: Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Posted on Oct 10, 2011
Singer sewing machine 251 -12 sewing in reverse
There is usually a lever on the front of a Singer that you push in to make it sew in reverse. You will have to pull the lever forward or push it in again, to get it to release and then the machine will sew forward.
Jul 27, 2016 | Singer Sewing Machines
How do I set the tension on my brothers lx2375?
Here's a manual to download. It should have the instructions you seek:
User Guide Manuals LX2375 United States Brother
Aug 09, 2015 | Sewing Machines
SINGER TOUCH N SEW 771
Use the wheel at side of machine and gently push back and forth it should release reverse lever
Mar 04, 2015 | Singer Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
I have my Mother's Brother XL3750, no book or accessories. It will sew in reverse only. I don't even know where the reverse button is. The only thing that I have tried is the big lever front...
you can download a manual for your machine from the Brother website,
link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000452/bm2736xl26i35i375ug04enes.pdf
Reverse is the big lever in front but it should be sprung so you need to hold it down to reverse; if your machine is only sewing backwards, this lever might be stuck or locked into position. Check out page 25 and 26 in the manual for specific info.
Sep 10, 2011 | Brother XL3750 Mechanical Sewing Machine
Lever is stuck in reverse
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
Brother CS-8060
if you are looking at your machine there is a trio of "buttons" it the one on the right looks like an upside down u with an arrow pointing down on the right side... press that for reverse...
Aug 21, 2008 | Brother CS-8060 Computerized Sewing...
Reverse lever
lever must be locked in. if possible, you must open it and try to look for something blocking it. maybe a faulty spring or something.
Nov 24, 2007 | Brother LS-1217 Mechanical Sewing Machine
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Brother xr-65
This happened to me too! Make sure your buttonholer isn't pulled down and locked in to where it's making the machine sew backward. That's what happened to me.
Jul 28, 2006 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
