Question about Acer Aspire L100 PC Desktop
Acer aqspire When I push power, the LED lights but the computer,s only action is to "beep" every 3 seconds
  • Anonymous Apr 14, 2008
    This has now happened to me 3 times in one year. I make sure that I have good ventilation, and that the area around my desk top is regularly dusted without a rag and a non static closth.
    Problem Solver:
  • 30 Answers
Check your RAM there is dust or no correctly working
Posted on Oct 17, 2007
My computer will not power up when i push the power button its an acer aspire desk top
First make sure that computer is getting power, check that AC cable is connected and led light is on behind the computer. Remove the cable for a while, then but it back in. Push down the power button for 10 seconds. Then try to start the computer.
Apr 14, 2014 | Acer Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
Acer 5100 will not power on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 06, 2012 | Acer Computers & Internet
Computer won't start. gives an error code of 1 long beep, then 3 short beeps , then shuts off. has phonix bios
I would try the following steps, if these don't work, contact Acer.
1) Remove power cord and battery.
2) Hold down power button for 5 seconds.
3) Replace power cord and battery.
4) Try to turn machine on.
If these didn't fix it, it's a hardware issue. Contact Acer for warranty support.
Mar 01, 2011 | Acer Computers & Internet
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
It sometimes takes me over an hour of pushing the power button on and off. When I push it on, it beeps 3 times and then nothing happens. What's wrong?
there is problem with the RAM of your Computer. please check it with replacing the RAMs. hopefully it will work fine.
Please dont forget to RATE my answer
Sep 05, 2009 | Acer Aspire 9300 Notebook
My acer aspire one A150 is frozen
It sounds like you have a bad motherboard, but taking it apart is something I can't explain here. Each laptop is different. There is a geeric procedure that works,but you nedd experience to deal with the differences you'll encounter between different laptops.
I'll see if I can find a disassembly diagram for you. Thats usually all the manufacturer will provide in the way of a service manual.
Jul 28, 2009 | Acer Aspire One A150-1006 Notebook
Acer Aspire L100 PC Desktop Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
