Question about Bissell CleanView II Plus Upright Bagless VacuumVacuum
No suction up into the canister
There is no suction into the canister. I keeps getting clogged in the hose
  • gpchubon May 23, 2009
    I have no suction from the bottom of the vacuum, but I do have great suction when I disconnect the hose for doing stairs. There's no blockage in the hose after the connection.
  • 104 Answers
Try cleaning the Hepa filter and the rear filter behind the motor
Posted on May 23, 2009
Red light indicator comes on with suction only
Hi there Christy! It sounds like you possibly have a clog in your main hose. To check the hose for clogs remove the hose completely from the vacuum from both ends. Use a broom stick or something similar to loosen and remove any clogs from the hose. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose. Hope this helps!
Jun 16, 2014 | Hoover Nano Cyclonic Compact Bagless...
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
Suction cuts out, no clogs found in any of the inlets. It's an LG V200R, 4 months old. Returned it to LG twice and it still happens after a couple of uses. Is this a design flaw in the vacuum? Do you...
I bought the lg kompressor 2 mo ago. Made hissing sound and no suction to canister, but the hose had good suction. The inlet was clear, but there was a clog up inside the vacuum between the inlet at the beater bar and the lower hole that empties into the canister(very hard to find). Use a wire hanger to clear it out. just keep jamming it up there and it will clear eventually. There is a clog somewhere, you just have to find it.
Sep 04, 2011 | LG Kompressor Upright Vertical Cyclone...
Vacuum keeps spitting dirt back out. will not **** up the dirt
Check the hose for clogs. This problem is generally caused by the power nozzle brush running, but there's no suction to pick up what it sweeps to the hose, so debris just keeps getting scattered.
Disconnect both ends of hose. Drop a marble or similar small item down one end of hose and lift hose until the item comes out other end. If it doesn't, there's a clog. You can try to clear it by connecting the hose to the exhaust port, sticking other end in a plastic garbage bag, and turning on vacuum. That should clear it.
If the marble does roll out, another possibility is a leaky hose, one with cracks, holes, and similar things that would cause a leak.
There are other things that could cause a loss of suction, but these are the most common.
A bad switch is also possible, but less likely.
Oct 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
My almost new miele Dog and Cat vac keeps telling me the bag is full when it's not (new bag, no clogs)and I have almost no suction. Any ideas?
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Aug 12, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Cloged, will not pickup Hose also cloged no suction
Generic problem for all Vacuums
Clogged, will not pickup Hose
Clogged, will not pickup Hose also clogged no suction
I’m not sure if you have a canister or an upright but there are thing you can check on both machines, canisters – you can check the suction from the end of the hose and work your way back to the canister, start with the end of the hose, then remove the hose and check the suction on the vacuum – most clogs are in the hose – if you have a hose clog run a steel ball thru the hose to see if goes thru all the way if it does than check the bad and the filter, if those are ok you may have a bad motor. If it is an upright, make sure the height adjustment is correct and is adjusted correctly, then use the steel ball and run it thru the attachment hose to see if that is blocked or clogged. Then check the belt and the extension wands to see if there is a blockage there as well, if you have good brushes and the tone changes from high to low and the brushes are actually hitting the floor, then you may have a motor problem and then you might have to replace the motor or fan assm. I hope this was helpful.
Apr 21, 2008 | Vacuums
No suction
No suction
no suction
Bissell CleanView II Plus Upright Bagless VacuumVacuum Logo
171 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
