Question about Sharp Televison & Video
Not power on
That is a 110v input tv model. i forget it and i plug it in a 230v power. so now it not working, how to repair it self ...
    Top Expert:
  • Sharp Master
  • 74,383 Answers
The main poser supply bard might have damaged. "Not might"; have damaged. Replace this board as card basis. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Dec 26, 2013
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: Power cable problem for SHARP AQUOS TV 42 inch
The voltage rating of the cable is not a problem. For all home appliances, including TV sets, the voltage rating of the power cable is supposed to be up in the 600 Volt to 1000 Volt range depending on the particular manufacture of the cable. This is not an issue. I have never seen a home appliance that could handle more than 240 VAC.
As for the Amperage rating of cable, it is more than adequate for the appliance that the cable is sold for. The 220 Volt appliances use about 1/2 the amperage that their equivelent 120 Volt appliances use. This is because the wattage for the power consumption is normaly constant.
The power cable is not a factor here. If the power supply in the TV can take the 220 VAC, and the 50 Hz power line frequency then there are no problems from that point.
Jerry G.
Posted on May 21, 2008
budmrtn
  • 11361 Answers
SOURCE: tv did not turn on
Look at the power supply to see if anyhting burnt, fuse, bad capacitors. I doubt that the power cord is bad, the same size fuse should be used as the original one.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 04, 2009
While baking there was a spark and smoke that blew out the breaker
Sometimes there are two breakers, one for the 110v and one for the 230v. The 110v works the light and the clock and such, and the 230v handles the heater elements. If the breaker blew, you might need a repair though. Also always be careful when working with electricity please.
Dec 20, 2011 | Frigidaire Kitchen Ranges
Samsung TV plugged into the wrong power outlet
maayong buntag dong,,you can do it by your self i teach you how,Open the back cover of your TV.Along with the AC power cord there is a component called varistor this varistor serves a protection for over voltage.Its color is green round shape with two terminal pins just remove it from the board replace the fuse with same rating and your tv will work again..anyway im from bicol albay.
hope i helped you..
please rate my help tnx dong!
Jun 06, 2010 | Televison & Video
110v lcd tv was plugged to 22ov outlet
Hello nik286, hi, check first the label at the back of the TV, look for a voltage input something like a 90V-240V, if you see this, its an autovolt system, this type of power supply input is standard nowadays. Assuming your asking what would be damage, this could be anything from the fuse, thermal resistor, rectifier diodes, and the regulator IC of the power supply board.
Apr 12, 2010 | Sansui 19 in. LCD TV
Have a Plantronics Cordless phone with the supplied Power Charger (input 110v, output DC9v.500mA.)using in UK with 230v/110v step down transformer, works perfectly. Then, like an idiot decided to use a...
You may have FAILED to check that the polarity matched. Some have the pinpositive, the other the sleeve.
It is UNLIKELY that muchwas damaged beyond the power regulator in the base unit. Should be relatively inexpensive repair.
Dec 26, 2009 | Hitachi 12v 3/8" Driver Drill Kit with...
Pluged into the wrong voltage
You have to replace the power supply with exact voltage and amperage.
Be careful next time.
Regards;
Hassan
Jul 27, 2009 | Fender Passport P-51 Consumer Microphone
What voltage will a HP 6715b accept?
hi no need of transformers.. ur lappy is ready to accept 230v-240v...
Feb 07, 2009 | HP Compaq 6715b Notebook PC
18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Televison & Video Logo
19 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
