Drain pump running continuously even with no water
Had a washcloth stuck in lint trap. I took everything apart and removed the rag. However, the drain pump is still continuously running. I have done all the diagnostic tests and everything is good except C8: the draining does not stop.
    Problem Solver:
  • 12 Answers
You might want to try manually filling the machine with water using buckets or a hose. Perhaps there is some type of switch that is stuck on. My thought is that if you fully load the Machine with water and let it run through it cycles it may somehow reset the switch. It's worth a shot.
Posted on Dec 26, 2013
4 Suggested Answers
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
  • 1531 Answers
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Posted on Jan 31, 2010
  • 10865 Answers
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
Posted on Mar 08, 2010
How to take apart to clean out lint
For front loaders in general. Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Washing Machines
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Sep 07, 2009 | Bosch Dryers
The lint trap on my dryer is moist.
I don't know what's causing the smell, but the moist lint trap and the "takes two cycles" sounds like the exhaust vent is partially blocked.
You can ask the apartment manager to clean it out, or you can take a stab at it yourself with an electrician's fish tape, a plumber's snake, or a dryer-duct cleaning kit. (I picked links from Ace, but you can get them at any hardware or home shop)
Pull the dryer out and detach it from the ductwork. If you're using the fish tape or the drain auger, then you'll want to tie a rag to the end -- washcloth to dishtowel sized at the biggest -- to wipe the lint out of the ductwork. If you've got the duct-cleaning-kit, then use the brush that comes with the kit.
Work your way up and down the ductwork as far in as you can reasonably reach. Chances are good that you'll soon have a huge pile of lint on the floor, and much better airflow through the ductwork.
Hook up the dryer and things should go much better on the next laundry day.
Aug 03, 2009 | Whirlpool LER5636P Electric Dryer
Washing machine will not empty
You have either go a coin or grip stuck in the pump which you may be able to see from the lint trap door
Lay the drain hose down into a bucket or outside the door (Take off any clips that may be holding it to the back of the machine first) that will drain the water off.
Remove the lint trap and see what is in there take a wooden barbeque skewer and try to turn the impeller of the pump, if it turns free then you need to take the hose off from the drum to the main inlet to the pump to see if there is anything in there
(A sock or other small piece of clothing may have been sucked down into the hose leading to the pump).
Worst case scenario is that the pump has failed and the only test for that is to put a meter on it and check for continuity
Jun 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cycle just continues with the pot symbol blinking
disconnect the hose and run it into a bucket, is it pumping freely?.
did you check the trap for a blockage?
You may have a leak in the pump housing area below the unit, this would cause the drain pump to run continually.
Jan 24, 2009 | Viking Designer Series DFUD041 (Premium)...
GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Oct 29, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
