CZ2011P comes on and runs for a couple of min. And shuts off.
    New Friend:
    Problem Solver:
  • 5 Answers
Yes
Posted on Dec 26, 2013
MD 150T-7 eagle runs about 10 min: an then shut down and will not start some times until the next day
Sounds like catalytic converters. Pull the pre cat O2 sensor/s. If it stay running, replace the cats. just a note. Coils could do this. But they usually come back to life after a couple hours. Scan for codes.
May 25, 2016 | Eagle Cars & Trucks
250. What causes it to run roughly and lose RPM?
The Miller 212 has a 60% duty cycle. So for every ten minutes of welding the machine is designed to weld for 6 min and cool down for 4 min.
Sep 02, 2015 | Miller Welding Tools
I have a 93 dodge stealth that will start right up but after a couple minutes it just shuts off. And it wont restart for 20-30 min, it will restart only to shut off again after a couple of min.
I'm not positive, but I think your electronic ignition has something called a pick up coil that goes bad. Sometimes the engine may just die while driving, or just not want to run when it starts. You also may have a distributor cap that Mitsubishi made that has circuitry inside the cap, so replace the cap too.
May 08, 2015 | 1993 Dodge Stealth
Bakers pride deep fryer will only stay lit for couple of minutes and then shut off
Hi there!
Normally hi limit sensing bulb is thicker and shorter than that of thermostat.
Try tightening all wire terminal crimps and connection.
Regards.
Feb 05, 2013 | Imperial IFS40 Deep Fryer
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | GE DWSR463EGWW Electric Dryer
Dryer rune for a bit then shuts off - won't start
clean link from bottom of dyer and exhaust vent
Aug 07, 2009 | Kenmore 63942 Dryer
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
