Question about Toshiba REGZA 42RV530U 42 in. LCD HDTV
Need to remove tv stand
I need to remove the Tv stand from my tv
    President:
  • 1,077 Answers
There are 4 screws you need to remove to get the stand off.
There is 2 vertical screws near the ANT/CABLE port and 2 more vertical screws near the power cord.
The stand should slide out after that.
Posted on May 17, 2009
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
- the whole base is a single piece that slots into the bottom of the TV, with a clip release.
- the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
- the base is screwed into the TV, and you'll have to remove these to remove the stand.
If that doesn't help, please provide more details, like the make and model of your TV.
Dec 18, 2014 | Televison & Video
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
How to remove tbl stand from toshiba tv
Usually table stand fixing/ removal is written in related user manual of tv, please check user manual of tv, if you need more info, let me know tv model number of your tv.
Thanks.
May 28, 2010 | Toshiba REGZA 47HL167 TV
42'' Sense LCD TV Removing the Stand
THE WAY I DO IT FOR ALL TV
usually you got 4 screw in the back of the tv need the bottom
be sure to put tv face down on your bed you gone have a surprise
gone fall from the stand
and pull it from the tv by the buttom
Mar 06, 2010 | Televison & Video
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Mar 09, 2009 | Insignia 42" Flat-Panel Plasma HDTV
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Toshiba REGZA 42RV530U 42 in. LCD HDTV Logo
789 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
