Question about Iolo Technologies System Shield
Failed to initialize Systemshield.dll - Iolo Technologies System Shield
Webcam wil not come up
Unfortunately this is a very confusing error, and one that does not really have a simple to write out answer. libiomp5.dll is a newer way of Intel accessing webcams, while libguide_40.dll is the old way of doing it. For some reason there is already a program using the older version of the file when your webcam program attempts to initiate the newer method. What program are you trying to use?
Nov 21, 2013 | Dell Studio 17 (1749) Laptop black -...
Can not connect to the internet.
That's common in Vista. Click on Start > Find > Files or Folders , type in winsock .
Go to where the file is located via command prompt (start - run and type "cmd" (without the quotes). for example:
if the winsock.dll is located at c:\windows\system32\winsock.dll then type "regsvr32 c:\windows\system32\winsock.dll . If you did this correctly you should get a message saying "winsock.ocx registration successful" or something to that effect.
Restart the computer and hopefully it'll work. If it doesnt please let us know.
Apr 29, 2010 | Acer Aspire 5920-6727 Notebook
I got a remote controll helicopter and when I installed the software for the Flying Model Simulator, it brings up an error saying that D3DRM.DLL IS NOT LOADED.. What can I do to run this program so I can...
The D3DRM.DLL file is the Dynamic Link Library for Direct3D Retained Mode, an older DirectX display technology that was not included with Windows Vista. Direct3D is used to render three dimensional images in applications where performance is important; the most common examples of which are games, CAD drawing programs and graphics editing software.
The error message displayed varies by program, but some some of the more common ones are:
  • "Failed to initialize Direct3D with current settings"
  • "Cannot find the file d3drm.dll"
  • "This application has failed to start because d3drm.dll was not found"
  • "D3DRM.dll is not loaded"
This error is usually a sign that the d3drm.dll file has been deleted, corrupted or altered in such a way that makes it unusable to your program.
To fix errors like this:
1. Install the latest version of Microsoft DirectX. It will fix the d3drm.dll error.
2. Uninstall the game or software program and then reinstall it again.
3. Update the drivers for your video card.
4. If it doesn,t work copy d3drm.dll file to the system folder.
Hope it helps.
Mar 18, 2010 | Microsoft Windows Vista Ultimate Edition
This is message error appear during I install canofile : RNBOVDD.DLL An installation virtual device drive failed initialization choose.'close' to terminate the application
The RNBOVDD.DLL is a Device Driver used for DOS and Windows 16-bit...so needs to be removed hence follow the steps listed below.
Run the Registry Editor by typing in regedit in the run search bar and Select the HKEY_LOCAL_MACHINE window.
Double click on SYSTEM. Double click on CURRENT CONTROL SET. Double click on
CONTROL. Select VIRTUAL DEVICE DRIVERS.
Double click on VDD:.......RNBOVDD.DLL line on the right side of the window.
Delete RNBOVDD.DLL. Confirm by pressing OK.
Shutdown and restart Windows.
ALL THE BEST...................
Feb 21, 2010 | Canon Canofile 2.01 Full Version for PC
Computer error code
it is because of missing some dll files .that are the library files of windows.so you reinstall your OS
Mar 12, 2009 | Computers & Internet
Lifecam install failed
Could you let me know if this worked for you?
Jan 03, 2009 | Gateway GT5220 PC Desktop
Message: DLL initialization failed. Trying to install webcam
then what can you please describe the issue further
Firestorm problem
Error message: "Explorer caused an invalid page fault in module Kernel32.dll"
http://support.microsoft.com/kb/187965
OR
User32.dll or Kernel32.dll fails to initialize
http://support.microsoft.com/kb/184802
Dec 16, 2008 | S3 PCI VIDEO CARD VISION864 GACD2 86C864-P...
Error message on laptop boot up
You need to reinstall the modem driver ..
Dec 12, 2008 | Computers & Internet
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
Computers & Internet Logo
237 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Jax Planet
Jax Planet
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
