Question about Toshiba 27A32 27" TV
How to switch from TV to DVD on a Toshiba Model 27A32 when you do not have the remote control for the TV
    Top Expert:
  • Toshiba Master
  • 75,581 Answers
Without its remote control, you can't select its inputs. Even some universal remote controls won't allow you to select this option. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, adn buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 26, 2013
4 Suggested Answers
Remmik
  • 56 Answers
SOURCE: uneiversal Remote Code
The model of the TV is not important as the code list is by Make only and usually list 3 ot 6 codes to try for each make. Having the Remote control model number is more important so you can find the right instructions and code for your remote.
Check here
http://www.jascoproducts.com/support/universal-remote-codes.asp
Posted on Feb 18, 2009
  • 20 Answers
SOURCE: lost the remote for my
The model number will be on the back of the tv. You'll have a model number serial number and a few other numbers. But for the price of a factory remote you can get a really nice universal....
Posted on Dec 07, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Toshiba TV model 27A32 does not turn on. Is
Hi Dennis,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Feb 20, 2011
WHAT IT THE PROBLEM FOOR FAILING TO SWITH ON FROM STANDBY MODE
Have you tried to switch it on with the channel +/- buttons on the TV itself ? If this works, the batteries in your remote are dead. If it does not, then you have an electronic problem in the TV. Need a service-technician.
Jun 15, 2014 | Toshiba 27A32 27" TV
How to program a replacement remote
toshiba tv that" s kind tv easily to get & install remote control in rca brand. just follow inside instruction step by step to try each code# in front of your tv. good luck!
Jun 05, 2011 | Toshiba 27A32 27" TV
Lost the remote for my toshiba tv model 27a32, need the model number to replace the remote (prefer to get a toshiba remote rather than a universal)
Dec 07, 2010 | Toshiba 27A32 27" TV
I have a Toshiba tv/dvd combo. My remote will not operate the dvd
You might have to re-program the remote, here is the link for the owner's manual which tells you how.
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
Feb 19, 2009 | Toshiba CT-90157 Remote Control
Tv codes for a rca universal remote controller
Programminng an RCA remote cotroller for a Toshiba ,CE19H15 model
Jan 25, 2009 | Televison & Video
TV CODES
Toshiba codes:
021. 030, 031, 070, 071, 072
Oct 04, 2008 | Universal Remote Control Hampton Bay...
Remote for DirecTV wont control my Toshiba VCR/DVD combo unit
Its true sorry but there isnt any codes available for combos.
Feb 19, 2008 | Directv D10 DTV Receiver
Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Nov 08, 2007 | Toshiba 14DLV75 14 in. TV/DVD Combo
Toshiba 27A32 27" TV Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
