Question about Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player
Touch screen car audio
Touch screen not wok
How does it wok
They don't "wok". You have to get a Wok to wok. What is the real question?
Nov 29, 2014 | Cars & Trucks
How do I get my alpine iva-310 out of demo mode?
Go to https://www.manualslib.com/manual/529923/Alpine-Iva-D310.html or 1
Touch [SETUP] on the main source screen.
The SETUP selection screen is displayed.
Touch [OTHER SETUP].
The OTHER SETUP screen appears.
Touch [
] of GENERAL SETUP.
The GENERAL setup screen appears
Touch [
] DEMONSTRATION
Set to OFF
Good Luck!
Oct 27, 2014 | Alpine IVA-D310 Car DVD Player
JVC KW-AV60 BT touch screen car audio touch screen not responding
is there a diagnostic setting for touchscreen calibration. Could have gone bad. you are probably still in warranty, take that bad boy back
Mar 12, 2014 | JVC KW-AVX800 CD Player
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
I am really getting into wok cooking but have you got any tips for me?
Wok cooking is a really healthy and tasty way to cook but you have to know what you're doing otherwise it could all burn and stick. Take a look at this article that gives 10 tips to better wok cooking.
http://www.tigersandstrawberries.com/2006/01/16/stir-fry-technique-ten-steps-to-better-wok-cookery/
Feb 18, 2013 | Home
The touch screen problems.malfunction.touch screen lost function even touch.model no exad kw avx-800
if the screen gets wet it will corrode at the data wire and not pick up a signal
Jun 28, 2011 | JVC KW-AVX800 CD Player
Screen is broken will the phone stay locked
No, it will work, but the touch screen won't work to let you select what you want. It's really hard to replace the LCD screen (about 40 tiny tabs to solder). However, if it's only the touch screen that is broken, you can buy new ones for $10 and only have to solder 4 tabs and it will wok again.
May 19, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I have a kemwood kfc-3012 12" sub what size amp do i need to run it
it depends on how loud you want it. If you are looking for it just too wok good, 400 watts would be good. don't exceed 1200 watts peak.
Nov 22, 2009 | Alpine MRD-M1005 Car Audio Amplifier
Can't get the DVD player to wok in my 2006 Lexus GS300
Repair Procedure
1. Confirm the customer's complaint of DVD RSE system inoperative.
2. For vehicles with Lexus Navigation System, perform the following procedure to turn OFF the RSE Lock function:
A. Press the INFO button to display the "Information" screen on the navigation unit.
B. Press the "Screen Setting" touch button on the navigation display.
C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display.
D. Press the DVD switch on the RSE system, (If a DVD is NOT already in the player, insert one) and confirm screen is "ON" and the system will play DVD's.
3. For vehicles without Lexus Navigation System, perform the procedure to turn "OFF" the RSE Lock function.
A. Push the audio control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "Rear Lock" is shown on the screen.
B. Turn the audio control knob so the display says "OFF" next to "REAR LOCK".
C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one.) and confirm screen is "ON" and the system will play DVDs.
4. If the above procedure resolves the concern, explain the system operation to the customer. This procedure is described in the "Audio/Video" section of the vehicle owner's manual.let me know lf this helps.
Jun 14, 2009 | 2006 Lexus GS
Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player Logo
54 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
