Question about Toys
Air hogs helix x4, must remove propeller (hair cought)
Got 3 long aired girls at home and a couple of hair got cought by mistake in a propeller. started to remove some with tweezer and needle, but must have a quicker way... thanks
SOURCE: My air hogs havoc cyclone
Try changing out the rudder or rudder may not be in neutral position.
Posted on Jan 04, 2009
SOURCE: How do I charge my Air Hogs Zipper?
I took the cord and put in the slot by the power switch and made sure the Zipper's power was off.
Posted on Nov 07, 2009
Testimonial: "THANK YOU FOR TELLING ME THAT NOW I CAN USE IT AGAIN!"
SOURCE: can i find a replacement prop for my kids air hog storm launcher
i called spin master and thy dont make them anymore
Posted on Dec 05, 2009
  • 26 Answers
SOURCE: my air hogs heli 360's
may have sheared inner gear that drives top rotor
Thats not good news sorry most store a very good about returning airhogs or replacing it for you those little heli can be so much fun good luck James
Posted on Dec 26, 2010
VLAD1431
  • 12 Answers
SOURCE: air hog helix 360...flybar is
They have little pieces that push on a ring to move it around. Open the heli and check that they are all inside of the ring. ~VLAD~
Posted on Feb 21, 2011
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
How to fix top propeller of the helix 360. It keeps flying to the right
The top is a balance bar. Assuming it's still intact and the metal pieces are there, you can round the edges with a file and cover the tips with a small piece of clear tape to give it more of an aerodynamic shape. The factory "square" shape actually makes the heli move around slower. This will also give you more movement in all directions... more response. ~VLAD~
Feb 07, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My Spinmaster Air Hogs Helix 360 4-Channel R/C Helicopter leans and falls to the left as i am tryin to lift it off. i tried the 'trim' but that doesnt solve it.
yes, this little heli does do that. it's likely due to balance and the the transmitter not remembering your trim settings after power off, but it's made that way. You have to steer it up, adjust the trim, land it.. and then it should rise better. You can try adding weight to the other side with a piece of clay to see if it solves the problem. If so, you can add metal or electrical tape to the landing gear on one side. ~VLAD~
Jan 22, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
The little flight stabelizer thingy above the propeller on my helix 360 is not working properly. i can hold it in my fingers and while the propellers are spinning i can see the stabelizer is tipping...
Check for damage to any of the linkage. You may also remove the tiny pin on the stabilizer and take it off. use a nail file or dremel tool to round the edges... giving it a more aerodynamic shape, and you a chance to make it balanced. After you do this, wrap each tip with a small piece of clear tape. This mod is good for any of the "square" AirHog balance bars.... it gives you more response and faster movement in all directions. ~VLAD~
Dec 30, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Just bought an air hogs helix 360. Now when i give it throttle and let it go, it flys straight left and hits the ground. Any solutions?
It's common for this copter to lift and drift to the left. Likely caused by weight, so you can add additional weight to the opposite sides landing gear, but ultimately more weight isn't better. Sadly there is no control for this drift, you have to compensate manually to keep it perfect. ~VLAD~
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Air hogs havoc cyclone will not stay in the air, what can I do?
if it is a piece of hair or sting, use some snippers and tweezer.don't worry about the shaft breaking.
Jan 06, 2009 | Master Heaters Air Hogs R/C Havoc Cyclone
Toys Logo
298 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
