Question about Supersonic Televison & Video
Portable dvd player not read dvd - Supersonic Televison & Video
    New Friend:
    Problem Solver:
  • 9 Answers
First, you should make sure the original dvd is intact, then you can send e-mails to the Supersonic support to get help.
Posted on Jan 08, 2014
4 Suggested Answers
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
  • 3 Answers
SOURCE: Polaroid PDX-0073 7 LCD Portable DVD Player
Hello
I had that problem, the problem is that where you put the disc (the black Circle) tends to get a bit loose so it moves downwards.
so the distance between the lens and the under surface of the DVD / CD is reduce, so the beam is NOT return to the lens.
The way I fix it is by pulling the black circle EXTREMELY carefully and SLOWLY while you are turning it.
Once is out, with a toothpick or a needle put a small amount of crazy glue in the inner walls of the hole that is in the center ( where the pole of the rotor goes in) this way the hole is reduce.
Wait till it dries, then gently put it back in, it will be a tight fit, IT MOST NOT GO ALL THE WAY IN!!!
By this i mean that you will see the pole of the rotor go into the hole, but it most not reach all the way, it should be below the surface. The distance between the end of the pole and the surface of the black circle should be THE THICKNESS OF THE BLACK CIRCLE.
The way to know that the distance is right, put in a CD and play some songs, then try it with a DVD.
If it reads no disc it means you inserted the disc to much, pull it out a bit, then try again.
Once it reads both CD and DVD, fill in the hole with a drop of crazy glue, this way the black disc will not move anymore.
One more thing, I do not recommend to use alcohol in the lens, 'cause some lenses are now made of polymers non resistant to abrasive, instead use a cue-tip (cottonete, little pole with cotton to clean your ear) moistened with bottle water or distiled water.
Note MOISTENED not soaked or wet.
Hope it works for you.
Best Regards
Luis.
Posted on Dec 29, 2008
sree-here
  • 61 Answers
SOURCE: rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
My philips portable dvd player says "wrong disc" when trying to play a dvd. whats wrong?
The lens isnt reading the disc get a lense cleaner n run it twice that should solve the problem
Apr 07, 2013 | Philips DCP851 Portable DVD Player
Mdp-1020 won't read any disk
When you start the portable dvd empty, does it 'load' the firmware first. Then you put the dvd in. It also needs to load the title etc. into the portable. If it does not read use TDK lens cleaner. If it wroks, fine. Otherwise rinse off the dvd with hot water, then blot dry defore trying in your portable again.
Aug 16, 2010 | Mintek MDP-1010 Portable DVD Player
Sony potable DVD player can not read DVD now
Dust has settled on the lens,. Clean it with q-tip and be very gentle.
Jun 23, 2010 | Sony DVP-FX810 Portable DVD Player
Hi my portable dvd player by insignia won't read
Try using a lens cleaner. Also, reset the unit to factory defaults. Ensure that the disk you are attempting to play is clean and scratch-free. If the problem persists, you may pursue service options through the place of purchase.
Jun 20, 2010 | Insignia NS-PDVD10 Portable DVD Player
Dvd wont play
Maybe the laser is broken. You should send it back for repair.
is it an original dvd?
Apr 22, 2010 | Philips PET702 Portable DVD Player
No valid DVD displays on my Toshiba SD-P1850
Most portable dvd players will not read burned dvd/cds. Please be sure to use originals in your dvd player. If you have a user's manual it should tell you if your player reads CDR's or DVD/RWs
Aug 07, 2009 | GPX PDL805 Portable DVD Player
My portable Poloroid DVD player cannot not read
Is there a way I can download information how to fix it on my own.
Apr 25, 2009 | Polaroid PDM-0714 Portable DVD Player
No disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
Nov 23, 2008 | Curtis DVD8017 Portable DVD Player
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
Televison & Video Logo
54 people viewed this question
Top Supersonic Televison & Video Experts
Demonic-2011
Demonic-2011
De ice
De ice
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
