Question about Eclipse Audio Players & Recorders
Eclispemp3 T2810C STUCK ON LOADING SCREEN
IT IS STUCK N LOADIN SCREEN HOW DO I FIX IT
3 Suggested Answers
  • 78 Answers
SOURCE: the UMD stay at the loadin screen
Your problem can occurs if there is any disturbance in the movement of lens in it's gear shaft or the white nylon gear which is moving this shaft. you can use white grease on this shaft as well as nylon gear also for the smooth movement of LENS and your problem should be solved. If above method does not works replace the lens.
Posted on Sep 10, 2007
ProsunPal
  • 60 Answers
SOURCE: RUNDLL Error loadin
Do you try safe mood ? If this startup msg dont appear in safe mood than the solution lies in microsoft configuration utility(msconfig}. Let me know what happened in safe mood.
Posted on Feb 14, 2009
My gotab 7 is stuck on the android loading screen how do you fix that
Turn off your gotab hold the volume up button and power button down at the same time. Then it should say recovery menu in red letters on the screen? Then press and hold just the power button again to hard reset the device I hope this helps?
Oct 05, 2014 | Aquachek Extra Strength Tylenol GoTabs
Sony camera cassette door stuck
Possible this can be a mechanical fault as the cassette body got struck because there was some stickers on the sides or if there was a loose link.
If so you can remove the top cover and gently tap on the cassetter as the cam is powered to allow the tape to wind back so as to eject.
If there is no unloading of the tape back to the cassette, then it can be failure of the loading drive, failure in the servo section in which case you will need to remove the covers and check the loadin IC, the power and the board.
Sep 14, 2011 | Sony HVRHD1000 Camcorder
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Loading Screen
did you ever find a fix for this?
Aug 16, 2009 | Car Audio & Video
RUNDLL Error loadin
If you have recovery or OS disk then
insert in cd/dvd drive
then
click on start>run
type is "sfc /scannow" without quotes hit enter
and let your procedure finish
once its done reboot your pc.
Note: there is space between sfc and / .
post back if it makes any changes and rate all anwers.
good luck
Feb 14, 2009 | HP Pavilion Media Center a1330n - AMD...
The UMD stay at the loadin screen
Sep 09, 2007 | Sony PlayStation Portable (PSP) Console
27 people viewed this question
Top Eclipse Audio Players & Recorders Experts
juanmireles1
Joseph Hoffmann
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
