Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
I have a 1996 polaris indy 500 efi first of all im not a snow machine guy and dont pretend to be one this machine was given to my boys by their grandfather who bought it knew i have had it about eight or ten years it has only 821 miles on it my boys just started riding it on their own this year it has ran great starts great just a couple of tugs on the rope even when its extremely cold out like i said it has ran great until four days ago then it started backfiring it sounds like the ecm or fuel pump keeps coming on and it is getting to much fuel i run premium gas in it put in a new battery beginning of winter new plugs ect the boys on on about their fifth or sixth fill up never had a problem called some local dealers in my area they just said we'll give you a couple of hundred bucks to trade for something else im not interested in that just looking for some pointers like i said it was a gift from their grandfather when they were younger now they are old enough to ride it i would like to fix it if it can be fixd thanks y email address is tjtransporttauber @ gmail.com
Ok I thinking with the info you posted I have a small thing you can check on the wiring harness by the pull start (recoil) side of the engine there will be a small black box this is a relay (Bosch 30/40) go to any parts store and purchase one cost is from 4.00 to 10.00 and replace it what I think is happening is when you try to rev up the machine it's breaking contact of this relay I hope this helps do not get rid of this machine I'm sure it's a simple fix also check for fouled spark plug this can cause similar issues I hope this help
Posted on Dec 26, 2013
SOURCE: I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Posted on Feb 17, 2010
SOURCE: I have a 1997 polaris
bad needle and seat in carburetors allowing gas leak by needle in carbs. Turn off gas when not in use and will help get by until you can replace them
Posted on Jan 03, 2011
SOURCE: I have a 1989 polaris indy 500 was riding on the
I don't know where you live -- but up here in Alaska ( where it is very cold ) we have problems with water getting into the fuel of just about everything ( condensation from sitting )and the snowmobiles I have here I have to drain the carbs every now and then to drain out the little bit of water that finds its way to the carb bowl. ( just a thought ).
could also be a blocked/dirty jet in the carb, to cover all bases I would remove the bowl from the carburetor and spray down all parts with carb cleaner and then re-install and then try and run the sled. ( 9 times out of 10 the problems are carburetor related ).
c...
Posted on Jan 23, 2011
SOURCE: I have a 1992 polaris indy 500 efi snowmobile and
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Posted on Feb 10, 2012
Jan 25, 2016 | Winter Sports
Jan 13, 2016 | Winter Sports
Oct 25, 2015 | Winter Sports
Mar 09, 2015 | Polaris New Genuine Polaris Snowmobile...
Nov 29, 2011 | Polaris New Genuine Polaris Snowmobile...
Feb 11, 2011 | Polaris New Genuine Polaris Snowmobile...
Aug 24, 2017 | Polaris New Genuine Polaris Snowmobile...
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Feb 01, 2009 | Polaris New Genuine Polaris Snowmobile...
377 people viewed this question
