Question about Jet 2002 Ford Mustang - Automatic, 3.8L V6 - Performance Module
Won;t start won' crank
Good battery, good starter and solinoid, everything works with key on position, ignition fuse blows when key is turned to start position, you can hear the solinoid click, engine turns by hand. What next?
3 Suggested Answers
  • 346 Answers
SOURCE: I am painting and turned
hello,please rate me as in 1 to 4 thumbs up for my answer.im disabled myself & have a scooter.Im sure this Document will give ya all the info you need,download:troubleshooting_2007 SHOPRIDER.pdf
do that on the Adobe Reader,save or better still print & store in a polythene sleeve folder so you can keep for future.Type in your brouser shoprider.com & scroll down till you see the PDF File i have give ya,or visit:www.alldatasheet.com to download it.Hopefully you should be sorted,i know what its like to be without your wheels Colin.
Posted on Aug 16, 2010
  • 108 Answers
SOURCE: 2000 camaroz28, wont start. turn key, dash lights
Have you checked for "Dirty Battery Terminals"? That is where to Start. Also, check for voltage at the Starter Solenoid Terminal using a person to turn the Ignition Switch to Start position. Often on a vehicle that is older, the Starter Solenoid can be literally frozen up with corrosion and cannot move when energized. If you are not getting 12 Volts at the Solenoid then you could have an open connection between the Ignition switch and the Solenoid. The firewall Connector and anything from the Ignition Switch to the Solenoid can be corroded or otherwise causing a high resistance or Open Circuit. Neutral or Clutch Safety Switch cold be out of adjustment and/or defective. If you cannot perform these simple tests, see a Professional ASE Certified Technician.
Posted on Oct 29, 2013
When I put the key in the ignition it doesn't try to start everything else comes on then shuts off. I drove it yesterday but now it won't work
The remote starter module is not getting an electrical signal when you turn the key to the on position after remote stating the vehicle. When you depress the brake without turning the key on the vehicle shuts down. The remote module thinks the key is off even when you turn it on. There is a loose connection or the remote start device is defective.
Jun 04, 2014 | 2005 Chrysler 300
Won't start, won't crank
have you crossed the solenoid terminals and checked the starter for operation? may have the battery cable burnt thru to ground by the exhaust side of the motor..it happens if the cable is up against the block..
Dec 26, 2013 | 2002 Ford Mustang
Acura Tl 2005 won't start
This vehicle is equipped with a chipped ignition system.On your dash warning lights,when turn key into on position you'll notice a yellow key symbal, it should flash then go out. If it flashes then goes to solid on, it means the system does not recognize signal from key. This can be because of wrong key(original valet key will not start car) or key for whatever reason has been deprogrammed. Which can only be done by dealership unfortunately. If system is working(light does go out) then you need to look at possible brake switch sensor,park/neutral safety switch on shifter, and for signal at started when key turned to start position
Apr 08, 2013 | 2005 Acura TL
Won't start. key works in aux position but not when turned all the way
If you have power in aux position(ex.)radio works but doesn't when you put the key in the start position,the ignition switch is bad,the contacts are warn out for starting/cranking&run positions,these are used everytime you start your car,but auxillary is ony used once in awhile(ex.)your sitting listening to music while waiting for someone to come,but if you do have radio in the run position,but no cranking/starting you could have a blown resistor on fire wall or fuse for ignition,or the starter has called it quits,good luck I don't know if the starter is clicking rapid or just one click or just no power not cranking or cranking a better description of everything that happens will make this alot easier
Dec 29, 2012 | 2000 Dodge Grand Caravan
2001 jeep cherokee sport will not crank
But those are ignition parts. If the car won't crank, there is a problem between the battery, ignition switch, and the starter.
Try this, Darren: With key on, does your dash light up, gauges working and check engine light on? Turn key to start. Do you hear a click form the area of the starter? If you hear the starter solenoid click, and you know the battery is charged up good, then likely the starter is out, and needs to be taken off for testing or replacement. But that is assuming that the battery cables and their.connections are good and allowing full battery power to the starter.
If you hear no click in start, turn the headlights on and watch their intensity while someone turns key to crank. If the lights dim noticeably and no cranking, then the starter is bad or needs testing. If the lights don't change intensity when key is at crank position, then possibly the starter solenoid is bad or the circuit from ignition switch to the starter solenoid is not allowing current to pass. Take off the small wire (brown, I think) from the starter solenoid and see if it has power when key is in crank position. If it has power, the starter has to come off-it or the solenoid is bad. If no power on the solenoid wire with key in crank, then the circuit from ignition switch to the solenoid will have to be checked. There are at least a couple of components in that path- one is the starter relay, another is the neutral safety switch (or clutch switch on manuals). Also if no power on the solenoid wire, check the 30 amp fuse in the power distribution center by the battery. It may be fuse # 10, at least it is on a '97 Jeep. Heck, check all your fuses while you're at it.
Good luck.
Jun 02, 2012 | Jeep Cherokee Cars & Trucks
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
May 30, 2012 | 2005 Nissan Altima
Installed brand new starter, battery fully charged, and still wont crank. It starts when I kick start it. 1988 nissan pathfinder. What else could be the problem? Relay switch? Or ignition? Please help
Check the ignition switch, and the wiring to the starter solenoid. Get someone to turn the key to the crank (start) position and check for voltage at the starter solinoid. Check the starter relay and all fuses.
May 09, 2011 | 1988 Nissan Pathfinder
Turn key battery full good starter nothing dimms down just like i am not turning the key
check the wiring to the starter sounds like your starting wiring is not making good contact if not test with a test light and check the fuse hope this helps
Sep 11, 2010 | 1990 Chrysler Imperial
04 chevy 2500HD start relay /Circuit braker turns off @ key crank
Make sure battery has a full charge and battery connections all good. Any fuses in the diagram, test for voltage, some are hot all the time, some go hot with the key on.
Use a digital multimeter across battery posts, everything off, the generic spec for a full charge is around 12.6 volts. Leave the leads hooked up to battery, have a helper turn key to crank, how far does it drop? In my opinion it shouldn't drop much under 10 volts, I wouldn't argue with 9.6 volts.
Mar 28, 2017 | Chevrolet 2500 Cars & Trucks
Starter wont engage
The problem is either the starter solinoid (located on fender near battery) or you are not getting power to the "s" terminal on the starter solinoid from the ignition switch. If you follow the positive battery cable from the battery you'll follow it to the solinoid. Remove the small wire from the terminal marked "s" on the solinoid and using a screwdriver jump from "s" terminal (not the wire) to where positive battery cable connects to solinoid. (with battery connected). If starter doesn't do anything the solinoid is bad. If starter cranks then you are not getting voltage from ignition switch through "s" terminal wire.
Feb 19, 2009 | 1997 Ford F150 Regular Cab
Jet 2002 Ford Mustang - Automatic, 3.8L V6 - Performance Module Logo
62 people viewed this question
Top Jet Electrical Supplies Experts
Steve
Gene Haynes
Are you a Jet Electrical Supply Expert? Answer questions, earn points and help others
