Question about HP Deskjet F340 All-In-One InkJet Printer
I need software installed to run hp f340 all in one printer
Need to print from Windows Millenium
  • 975 Answers
Photosmart for 300 series
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need it to be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your F340 HP Deskjet F340 All in One Printer Drivers
Apr 27, 2012 | HP Computers & Internet
PRINTER HAS INK BUT WONT PRINT
Use the "HP Printing Assistant" software, installed on your computer, to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are _not_ shooting the ink onto the paper.
Jun 06, 2011 | HP Deskjet F340 All-In-One Printer
After getting Windows 7 I can't use the scanner button on my F340 aqll in one and I can't figureout the scanner feature on Windows 7
It sounds like you installed the generic OS driver from Windows 7. This driver only works for the printer. (Alternatively, you do not have the monitor program running or the destinations set in the HP software.)
If you plugged in the data cable before installing the HP software, uninstall the printer (Devices and Printers) then disconnect the data cable (USB). Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128309& and select your Win7 version (32- or 64-bit). Then click Next. Expand the section marked driver and download the Full Software. Install the software. Connect the data cable when prompted to do so. (Try a new USB cable since scanning requires bi-directional communication with the printer and can fail when the printer works). Avoid using a USB hub or print server.
If you do have the HP software installed, check that the monitor program is running (Start > Control Panel > System and Security > Adminstrative Tools > Component Services > Services.) The line for the HP monitor should say started. You may need to download and install the patches or the diagnostic utility from the above site to find a specific problem with the Win7 installation.
Next launch the HP software and attempt to scan from the computer. Next use the settings that give good results to program the defaults for the scan destination buttons. Now try to use the scan buttons on the all-in-one.
Once you have the HP drivers for both the printer and the scanner installed, the Windows 7 Fax and Scan and Paint programs should let you successfully scan from the computer. (New scan for fax and scan. File > Import from Camera or Scanner > New Scan for Paint.)
I hope this helps.
Apr 24, 2011 | HP Deskjet F340 All-In-One Printer
I have a F340-all-in-one. Will not scan
i would suggest to download the software from hp.com
for this printer.. and then try to install..
note : download the full feature software only..
Oct 22, 2009 | HP Deskjet F340 All-In-One Printer
Printing problems - wont print from XP Prof or Windown Millenium
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Jun 07, 2009 | HP LaserJet 8500n Printer
Windows vista
Here is a link to HP Support to download the Vista software and driver.
F340 Vista Downloads
Uninstall any current software you have installed and reboot before downloading and installing the new software.
Nov 14, 2008 | HP Deskjet F340 All-In-One Printer
F340 issue
You need to uninstall any printer software you have installed. Reboot your computer and go to this site to download the Vista software.
You can get the full feature software and driver or order a CD.
Nov 08, 2008 | HP Deskjet F340 All-In-One Printer
Can not print from computer to printer
hi,
try the following:
> start-->run, type services.msc
> double click on print spooler and click on stop and then click on start. press ok and close all the windows.
> unplug the usb cable from the printer
> now go to control panel and open printers and faxes.
> right click and delete all the printer icons related to hp deskjet f300 series.
> now plug the usb cable back to the printer
> wait for few minutes while it installs the driver automatically.
> thats it... now try printing
thanks and regards
agnel
Mar 15, 2008 | HP Deskjet F340 All-In-One Printer
How to get scanner working
Windows XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1128297&lang=en
Click on:
HP Photosmart Software and Drivers: USB Support
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1128297&lang=en
Click on:
HP Full Feature Software and Drivers
On the next page, scroll down to "download only"
Click on the button.
In order to get the scanner drivers you need the large package install from www.hp.com. Above are the links for windows xp and windows vista scanner software.
Feb 13, 2008 | HP Deskjet F340 All-In-One Printer
HP Deskjet F340 All-In-One InkJet Printer Logo
123 people viewed this question
Seeker5211
Seeker5211
