Question about ION Block Rocker Explorer Sound System w/ Bluetooth
ION Explorer Bluetooth microphone not working
Microphone not working
I have an ion ipa56c block Rocker. The battery is brand new. It gets a full charge and only last a few hours . Help
Block Rockerâ„¢ Bluetooth iPA56C - ION Audio
www.ionaudio.com/products/details/block-rocker-bluetooth-ipa56c
Block Rocker Bluetooth iPA56C provides up to 75 hours of on-the-go sound with its long-lasting ... A high-quality microphone is included to get you started.
RE: Block Rocker Bluetooth model differences - Ion Audio ...
community.ionaudio.com/ion.../block_rocker_bluetooth_model_differe...
Jul 6, 2014 - IPA23 - Explorer Bluetooth, Block Rocker Bluetooth, Block Rocker ...Besides the addition of another bluetooth port and the 75 hour battery on ... Bluetooth models IPA56B or IPA56C..... and between the last 2 what the differences are ? ... I have a model that says it's a iPA56B but only has a 50 hr. battery life.
Amazon.com: Ion Audio iPA56D Block Rocker Portable ...
www.amazon.com > ... > Karaoke Equipment > Players
Amazon.com, Inc.Amazon.com: Ion Audio iPA56D Block Rocker Portable Bluetooth Speaker System ... I work at gm and have bought 4 bluetooth speakers before this one for work use, ....block rocker battery power lasts only a few hours and blue tooth stopped ...
Amazon.com: ION Block Rocker Bluetooth Portable Speaker ...
Amazon.com, Inc.Ion Audio iPA76A Block Rocker Portable Bluetooth Speaker System with ..... I work at gm and have bought 4 bluetooth speakers before this one for work use, All of .... block rocker battery power lasts only a few hours and blue tooth stopped ...
ION Audio Block Rocker, Job Rocker, and Tailgater - Battery ...
noterepeat.com > ION > Portable Audio
Feb 08, 2016 | Tablets & eReaders
MY PHONE IS RECORDING BUT I'M NOT GETTING ANY SOUND. WHY?
The Microphone maybe damaged, or you may have a bluetooth device linked to the phone during recording, which would have the mic on whatever bluetooth device that was attached (and had a mic) be the recording point. In the event your microphone is damaged, you should find a someone who can replace the microphone on your phone. If there is a bluetooth device connected while your trying to record, you may want to goto control center by swiping your finger up from the bottom of the screen upwards, or go directly to settings / bluetooth, and temporarily disable bluetooth.
Oct 30, 2014 | Apple iPhone 4 Black Smartphone
Internal microphone
Usually the speakers on the laptop would act as a microphone- go into speaker properties, enable microphone and see it reacts. Bar that, you could go with the usb or bluetooth microphone route (I use the same headset for my phone as a microphone for my pc)
Sep 22, 2012 | Computers & Internet
Is there a driver that i can download to make the h390 work with my pc? i want to use it as a microphone. i just installed the dell truemobile 355 bluetooth+EDR in my laptop.
Push your power button on the headset toward the microphone. The light should be solid blue for pairing mode. On your laptop open up your bluetooth control center (if you're not sure where it is, give us your exact model of pc and your version of windows.
The first time you pair the headset, it might ask you for the security code. It is supposed to be 0000, but try 1234 if that doesn't work (or what ever you made it if it was changed).
Once it successfully pairs you should be able to use it like a microphone.
Please leave feedback if you found this helpful. Thanks.
Mar 25, 2011 | Motorola Mobility H390 Bluetooth Headset
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
Power
Well most probably there is a battery problem, you need to replace the battery in your bluetooth headset, most of these models are powered by Small Lithium Ion or NiMh rechargeable batteries and these like cordless phone batteries are designed to be replaced at some point in its lifecycle. Find the even **** on the bottom side of the unit, where the microphone boom is attached. Place the edge of the flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up. then you see the battery.
Good Luck!!
Jun 08, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My Bluetooth headset's microphone stopped working
Same Problem Here. Restored the 8220 flipphone to factory settings. Dint work either.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Microphone not picking up any sound in bluetooth mode.
Hi Joe,
First, I would go to the Garmin website and update the bluetooth software. Garmin just released v3.4 a few days ago (November of 2008). Use their webupdater to upgrade the BT firmware.
When you update the firmware, it will erase your phone paring data and you will have to re-pair the phone with your Nuvi.
Now, if that doesn't fix your microphone issue, you have either one of the following two problems:
1. The microphone is a condenser microphone. It's about a 1/4" in diameter and sits behind the front slot located in the lower left hand corner. The microphone has two wires (red & black) that run from the microphone to the main board. At the end of the wires is a 2 position plug that plugs into the main board. This plug can come loose as there is no lock mechanism on it.
2. The microphone is defective.
Please do not try to take apart your Nuvi unless you have the right tools. I have received many emails from people who have further damaged their Nuvi, trying to get it open.
Please let me know if you need further help with this problem.
Good Luck,
- Jim
Nov 18, 2008 | Garmin Nuvi 660 GPS Receiver
Motorola IHF1000 bluetooth
Hey mawcab,
Based on the information provided it sounds like your microphone is not working. There a possibility it could simply be unplugged from the car kit control module. It will look like a head phone plug. If your car kit is aftermarket it was probably installed under the steering column. Check for a black box with an unplugged wire.
What type of work was done on the car?
Hope this helps!
Nov 05, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
ION Block Rocker Explorer Sound System w/ Bluetooth Logo
98 people viewed this question
Top ION Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an ION Baby Gear Expert? Answer questions, earn points and help others
