Question about Breadman TR845 Bread Maker
My bread maker doesn't knead correctly (It is an Breadman TR845). If I added water, It can turn very slowly. However when I add the other ingredients. The KNEADING PADDLE stopped tunning. I only hear the noises.
  • 3 Answers
I had the same problem with my Breadman TR845. I made the first loaf O.K. but the knead paddle would not turn much when it had flour in the bread pan. I took it apart and discovered that the timing belt had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle a little. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the toothpaste cap in half and had to use a metal file to get it the right size. It needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the space so that it could slip over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are lots of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Posted on Nov 19, 2010
  • 69 Answers
Sounds strange. Usually the paddle has a key (the shape of it is irregular and it fits into the sleeve on the spindle or shaft) Either the shape has worn and it no longer fits or the spindle or shaft is not turning with the motor which could mean that the connection with the armature of the motor is damaged.
You could contact the manufacturers or ask afriend to examine it for you which would need taking it apart.
Alleluia
PTL
Posted on Dec 02, 2008
Why won't my paddle turn
My paddle won't turn in my Breadman TR 400. - Fixya
www.fixya.com/support/t20366573-paddle_turn_in_breadman_tr_400
Sep 27, 2013 - Posted on Sep 28, 2013.
Breadman TR850 Plus Bread Maker Paddle turn ... - Fixya
www.fixya.com > ... > Breadman > Breadman TR850 Plus Bread Maker
Paddle won't turn in the breadmaker with any resistance My breadmaker paddle won't turn under pressure. I put all the ingred. in and turn on the machine.
Amazon.com: Customer Reviews: Breadman BK1050S 2 ...
www.amazon.com/Breadman.../B003ZDNKSI
Amazon.com, Inc.Breadman BK1050S 2-Pound Professional Bread Maker with Collapsible ... So thepaddle turns and kneads while it goes in one direction. ... So, while I still love mymachine, I do a lot more bread by hand now. ..... Maybe I got a defective unit... but Iwon't be risking it... sending it back and exchanging for another brand.
Amazon.com: Breadman 34923 breadmaker paddle.: Bread ...
www.amazon.com/Breadman...paddle/.../B0041TMO...
Amazon.com, Inc.
Rating: 3.9 - ‎61 reviews
Turn on 1-Click ordering for this browser .... If I don't scrape down the sides a couple of times during the initial mixing, the loaf won't turn out correctly. ... This paddle fit my Breadman TR520 Programmable Bread Maker for 1-, 1-1/2-, and ...
Jan 01, 2016 | Breadman Bk2000b 2-1/2-pound Bakery Pro...
Can I make gluten free bread in the TR845?
Yes. Almost any bread machine can make a gluten free bread.
The key is to select teh correct settings to allow it to rise dequately but not too much.
Try these recipes:
Gluten Free Bread Machine Recipe White Bread
Mar 03, 2015 | Breadman Plus Tr845 Bread Machine
I am looking for a bread manuel for breadman plus model TR845 can you please advise?
Hi
To download the manual please click on this link:
Breadman TR845 Manual
Hope this helps...please post back for further assistance.
Daniel
Jan 10, 2011 | Breadman TR850 Plus Bread Maker
Used the breadman successfully 6 days ago. today; nothing happens. Window states "knead" but nothing happens at all.
Are you making a different kind of bread than you did the first time?. If so some machine programs have a delay before they start kneading such as the whole wheat cycle. Also some machines delay the kneading process while they warm up the ingredients. If it is colder where you live now than itw was 6 days ago that could be a factor.
Oct 12, 2010 | Breadman TR845 Bread Maker
Does the breadman tr845 use a belt to turn the dough mechanism? if so where can i buy one?
Yes, the Breadman TR845 uses a belt to connect the knead paddle to the motor. I had a problem with my Breadman so I took it apart. It turned out for me that the belt was fine but it had slipped off the plastic gear. The belt was still around the shaft of the motor so it could only turn if the bread pan was empty. The belt is a timing belt with integral teeth. I needed a small space washer that would keep the black plastic gear from slipping on the shaft and allowing the belt to slip off the gear. There is a lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacer washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed it to be 1/4 tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft of the motor. The spacer keeps the black plastic gear from sliding and it keeps the belt from slipping off the gear. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are losts of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Jan 17, 2010 | Breadman TR845 Bread Maker
I have a Breadman Model: TR845. It seems that the gear in the actual machine that turns the knead paddle is striped. It turns when the pan is empty ... so I know it is working, however with dough inside or...
I had the same problem with my Breadman TR845 that I bought used at Goodwill. I made my first loaf O.K. then could not get the knead paddle to turn except when the pan was empty. I took it apart and discovered that the timing belt (flat belt with integral teeth) had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle only when empty. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is a lip only on one side of the plastic gear so it if moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
Steve S.
Apr 27, 2009 | Breadman TR845 Bread Maker
I need an instruction manual for a Breadman TR 845
While searching for a replacement pan for my Breadman TR845, I came across this link http://www.creativehomemaking.com/download/Breadman_TR845.pdf It's the manual you need.
Jun 20, 2008 | Breadman TR845 Bread Maker
Breadman TR845 Bread Maker Logo
281 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
