Question about Brookstone Big Blue Studio Wireless Bluetooth Speaker
Trouble pairing iPhone w big blue live
My iPhone indicates pairing is discoverable but won't connect. When I turned on the big blue I did not see a red and blue light but two blue lights, which indicate no connection. Why is this happening and how can I fix Iyer?
Big blue won't pair with iPad even though the iPad shows it's discoverable. Also, when I connect speaker it ipod using cable, it beeps but won't play.
That's because the speakers are broken. Look in the User guide for reset instructions. If that doesn't work buy new speakers.
Apr 21, 2014 | Brookstone Big Blue Live Wireless...
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
Zk s9 bluetooth pairing
go to bluetooth menu on iphone. delete all zk s9s there. Make sure the zk is not already connected to your ipad. Only one live connection is allowed at the same time.
Apr 01, 2014 | Radio Communications
Iphone won't detect bluetooth
It's probably not the speaker, your phone is not recognizing the device. This is the link How to troubleshoot Bluetooth Connections from Apple:
http://support.apple.com/kb/TS4562
Dec 25, 2013 | Brookstone Big Blue Live Wireless...
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
When I turn my iPhone Bluetooth on it won't find the Craig blue tooth speaker!
Any Bluetooth device MUST be discoverable for the phone to find it.
Does your Craig have any setup program / configuration where you can set it to be 'discoverable' ?
Feb 17, 2013 | Cell Phones
IPhone 4 s not recognizing the 232
Once you make your iphone discoverable, then put the Plantronics 232 headset into pairing mode by pressing the call control button until it flashes red and blue. If it's not flashing red and blue, then it is not in pairing mode. Below is a link for the pairing instructions for the 230 headset (which is the same as the 232):
Plantronics Explorer 230/232 Pairing Instructions
Good luck from Headsets Direct!
Nov 23, 2011 | Plantronics Explorer 232 Bluetooth Headset
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
Iphone bluetooth codes
Unless the code has been changed, the default code is 0000 (four zeros). Be sure the phone's bluetooth setting is turned on and discoverable. Next press and hold the headset's power button until the light turns on steady. Then using the phone select "search for a new device", when it discovers the headset it will ask for the PIN number, enter 0000, then select pair. It should take only a few seconds. When done be sure to turn discoverable off so other bluetooth enabled devices cannot access your phone. Good luck to you
Oct 17, 2009 | Apple Cell Phones
Brookstone Big Blue Studio Wireless Bluetooth Speaker Logo
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
