Question about Frigidaire FAC124 wall/Window Air Conditioner
Window Air conditioner installation
The window is an up-and-down type and the AC dimensions are for a window 21-35" in width. Mine is 45". I'm stuck. How should I seal the sides? I believe the unit - Zenith ZW5000 has side panels that will extend but not all the way to the sides of the 45" window, only a 35" window.
This is the only window in the room so I must use it.
Thanks!
Sandy
  • sos2day May 18, 2009
    Good idea. So how would I attach it to the air conditioner and the window frame?
I use sheets of styrofoam on the inside of the window. Cut it to fit the width and height you need to seal around the ac casing to inside window frame.
Posted on May 20, 2009
  • 148 Answers
You can make a wood cutout paint it the color of the house there is no extensions that wide
Posted on May 17, 2009
PROBLEM ON START WINDOW AC
Lg have 5uf capacitor installed in outdoor section along with comoressor unit. It bascially helps to rotate the condenser fan.
Mar 15, 2014 | LG Electronic Window Air Conditioner
My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
Hope this helped you.
Jul 14, 2011 | Frigidaire FAX052P7 Compact Room Air...
RE Portable AC units What are the dimensions of the window kit ? Thanks, Norm
Norm - The window kit is about 7.5 in. 'high', by up to almost 50 in. 'wide'. Minimum width as small as you like, if you can cut through plastic. Exhaust hose is 6 in. diameter. Any sliding window should be fine. However, you can customize it as necessary, to fit just about any type window.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool ACP092PR Air Conditioner
What is the size of this air conidotioner model number ESA3109-L
Do you mean the amount of energy that it uses? It is a 10,200 BTU air conditioner and is recommended for a space of 475 sq. ft.
If you mean the dimensions of the window unit itself when installed, then the space between the window casings must be between 24 1/2" and 38" wide. The height is 14 9/16" and the depth is 20 5/32". The AC unit itself is 14 3/8" x 19" x 20 5/32". See page 15 of the manual (16 of the pdf) for the entire set of dimensions.
Retrevo has the manual avaiable here: http://www.retrevo.com/support/Haier-ESA3109-L-Air-Conditioners-manual/id/23148bh150/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
May 25, 2011 | Heating & Cooling
BTU of air conditioner?
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
May 13, 2010 | Whirlpool ACU102PK Air Conditioner
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Jun 10, 2008 | Frigidaire FAC124 wall/Window Air...
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Installation Issues
Measure the actual case. If it is less than 20", then it will fit by removing the window kit side pieces, to leave the bare case. Make sure the unit is well supported & level.
Jun 13, 2007 | Frigidaire OPP 5 FAX052P7 Air Conditioner
Frigidaire FAC124 wall/Window Air Conditioner Logo
677 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
